Hello , I can’t understand why a simple vector add with streams runs slower than without.
Time using streams : 27.577 ms
Time not using streams : 11.511 ms
#include <cstdio>
#include <cstdlib>
#define USE_STREAMS 1
#define gpuErrchk(ans) { gpuAssert( (ans), __FILE__, __LINE__ ); }
inline void
gpuAssert( cudaError_t code, const char * file, int line, bool abort = true )
if ( cudaSuccess != code )
fprintf( stderr, "\nGPUassert: %s %s %d\n", cudaGetErrorString( code ), file, line );
if ( abort )
exit( code );
return;
} /* gpuAssert */
__global__ void Add( int N ,int Offset ,float * devA , float * devB , float *devC )
for ( int idx = blockIdx.x * blockDim.x + threadIdx.x + Offset; idx < N; idx += blockDim.x * gridDim.x )
devC[ idx ] = devA[ idx ] + devB[ idx ];
int main()
int N = 4000000;
int Threads = 256;
const int NbStreams = 8;
const int StreamSize = N / NbStreams;
float *A , *B , *C;
gpuErrchk( cudaHostAlloc( (void**) &A , N * sizeof(*A) ,cudaHostAllocDefault ) );
gpuErrchk( cudaHostAlloc( (void**) &B , N * sizeof(*B) ,cudaHostAllocDefault ) );
gpuErrchk( cudaHostAlloc( (void**) &C , N * sizeof(*C) ,cudaHostAllocDefault ) );
for ( int i = 0; i < N; i++ )
A[ i ] = i;
B[ i ] = i + 1;
float *devA , *devB , *devC;
gpuErrchk( cudaMalloc( (void**) &devA , N * sizeof(*devA)) );
gpuErrchk( cudaMalloc( (void**) &devB , N * sizeof(*devB)) );
gpuErrchk( cudaMalloc( (void**) &devC , N * sizeof(*devC)) );
cudaEvent_t EventPre,
EventPost;
float PostPreTime;
gpuErrchk( cudaEventCreate( &EventPre ) );
gpuErrchk( cudaEventCreate( &EventPost ) );
cudaStream_t Stream[ NbStreams ];
for ( int i = 0; i < NbStreams; i++ )
gpuErrchk( cudaStreamCreate(&Stream[ i ]) );
#if ! USE_STREAMS
gpuErrchk( cudaEventRecord(EventPre ) );
gpuErrchk( cudaMemcpy(devA, A, N * sizeof(*A), cudaMemcpyHostToDevice) );
gpuErrchk( cudaMemcpy(devB, B, N * sizeof(*B), cudaMemcpyHostToDevice) );
gpuErrchk( cudaMemcpy(devC, C, N * sizeof(*C), cudaMemcpyHostToDevice) );
Add<<< N / Threads, Threads>>>( N ,0, devA , devB , devC );
gpuErrchk( cudaMemcpy(A, devA, N * sizeof(*A), cudaMemcpyDeviceToHost) );
gpuErrchk( cudaMemcpy(B, devB, N * sizeof(*B), cudaMemcpyDeviceToHost) );
gpuErrchk( cudaMemcpy(C, devC, N * sizeof(*C), cudaMemcpyDeviceToHost) );
gpuErrchk( cudaEventRecord( EventPost ) );
gpuErrchk( cudaEventSynchronize( EventPost ) );
gpuErrchk( cudaEventElapsedTime( &PostPreTime, EventPre, EventPost ) );
printf( "\nTime not using streams: %f ms\n", PostPreTime );
#else
gpuErrchk( cudaEventRecord( EventPre ) );
int Offset = i * StreamSize;
gpuErrchk( cudaMemcpyAsync(&devA[ Offset ], &A[ Offset ], StreamSize * sizeof(*A), cudaMemcpyHostToDevice, Stream[ i ]) );
gpuErrchk( cudaMemcpyAsync(&devB[ Offset ], &B[ Offset ], StreamSize * sizeof(*B), cudaMemcpyHostToDevice, Stream[ i ]) );
gpuErrchk( cudaMemcpyAsync(&devC[ Offset ], &C[ Offset ], StreamSize * sizeof(*C), cudaMemcpyHostToDevice, Stream[ i ]) );
Add<<< StreamSize / Threads, Threads, 0, Stream[ i ]>>>( N ,Offset, devA , devB , devC );
gpuErrchk( cudaMemcpyAsync(&A[ Offset ], &devA[ Offset ], StreamSize * sizeof(*devA), cudaMemcpyDeviceToHost, Stream[ i ]) );
gpuErrchk( cudaMemcpyAsync(&B[ Offset ], &devB[ Offset ], StreamSize * sizeof(*devB), cudaMemcpyDeviceToHost, Stream[ i ]) );
gpuErrchk( cudaMemcpyAsync(&C[ Offset ], &devC[ Offset ], StreamSize * sizeof(*devC), cudaMemcpyDeviceToHost, Stream[ i ]) );
gpuErrchk( cudaEventElapsedTime( &PostPreTime, EventPre,EventPost ) );
printf( "\nTime using streams: %f ms\n", PostPreTime );
#endif /* ! USE_STREAMS */
//for ( int i = 0; i < N; i++ )
//printf( "\n C[%d] = %f",i,C[ i ] );
gpuErrchk( cudaStreamDestroy(Stream[ i ]) );
gpuErrchk( cudaFree(devA) );
gpuErrchk( cudaFree(devB) );
gpuErrchk( cudaFree(devC) );
gpuErrchk( cudaFreeHost(A) );
gpuErrchk( cudaFreeHost(B) );
gpuErrchk( cudaFreeHost(C) );
gpuErrchk( cudaEventDestroy(EventPre) );
gpuErrchk( cudaEventDestroy(EventPost) );
printf("\n");
return 0;
