simpleP2P with multi GPU fails with cudaEnablePeerAccess - mapping of buffer object failed
I am trying to run the simpleP2P code sample from Nvidia Code sample site, and am running into an execution error:
simpleP2P.cu(154) : cudaSafeCall() Runtime API error 14: mapping of buffer object failed
The above points to the following line, which enables peer access on GPU#1 -
cutilSafeCall(cudaDeviceEnablePeerAccess(gpuid_tesla[1], gpuid_tesla[0]));
Following is the result of deviceQuery (please note that since I have 4 gpus so the similar info appears for the rest three, so I didn’t include it here); well this program works fine on another machine with similar configuration, but a mismatch in the driver version (Machine it doesn’t work - 275.09.04 ---- Machine it works - 270.35).
Device 1: "Tesla M2050"
  CUDA Driver Version / Runtime Version          4.0 / 4.0
  CUDA Capability Major/Minor version number:    2.0
  Total amount of global memory:                 2687 MBytes (2817982464 bytes)
  (14) Multiprocessors x (32) CUDA Cores/MP:     448 CUDA Cores
  GPU Clock Speed:                               1.15 GHz
  Memory Clock rate:                             1546.00 Mhz
  Memory Bus Width:                              384-bit
  L2 Cache Size:                                 786432 bytes
  Max Texture Dimension Size (x,y,z)             1D=(65536), 2D=(65536,65535), 3D=(2048,2048,2048)
  Max Layered Texture Size (dim) x layers        1D=(16384) x 2048, 2D=(16384,16384) x 2048
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 32768
  Warp size:                                     32
  Maximum number of threads per block:           1024
  Maximum sizes of each dimension of a block:    1024 x 1024 x 64
  Maximum sizes of each dimension of a grid:     65535 x 65535 x 65535
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and execution:                 Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Concurrent kernel execution:                   Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support enabled:                Yes
  Device is using TCC driver mode:               No
  Device supports Unified Addressing (UVA):      Yes
  Device PCI Bus ID / PCI location ID:           6 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
What could be the reason?
We had similar problems. simpleP2P does not work for 275.xx or 280.xx drivers. Downgrading to 270.xx driver fixes it.
It seems to be a bug from the newer drivers.
