simpleTexture - device emulation Error on execution
I am novice on CUDA.
I have added the command -deviceemu on the command line. On the bandwidthTest project, I can execute the out file without problems, following the CUDA_2_Quickstart_Guide.pdf
But on simpleTexture project, there were lots of error, I printed and attached the shell (7.bmp).
I use too the command simpleTexture.exe > out.txt
the out.txt is below:
Loaded ‘lena_bw.pgm’, 512 x 512 pixels
Processing time: 2544.159424 (ms)
0.10 Mpixels/sec
Wrote ‘…/…/…/projects/simpleTexture/data/lena_bw_out.pgm’
Comparing files
output: <…/…/…/projects/simpleTexture/data/lena_bw_out.pgm>
reference: <…/…/…/projects/simpleTexture/data/ref_rotated.pgm>
Test FAILED
Press ENTER to exit…
Thanks in advance
Recife - Brasil
Sidney Lima
www.sidneylima.com
