v4l2-ctl --list-devices
vi-output, imx219 30-0010 (platform:54080000.vi:0):
/dev/video0
vi-output, imx219 31-0010 (platform:54080000.vi:5):
/dev/video1
media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver vi
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: nvcsi--2 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "imx219 30-0010":0 [ENABLED]
pad1: Source
-> "vi-output, imx219 30-0010":0 [ENABLED]
- entity 4: imx219 30-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SRGGB10_1X10/1280x720 field:none colorspace:srgb]
-> "nvcsi--2":0 [ENABLED]
- entity 6: vi-output, imx219 30-0010 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "nvcsi--2":1 [ENABLED]
- entity 18: nvcsi--1 (2 pads, 2 links)
device node name /dev/v4l-subdev2
pad0: Sink
<- "imx219 31-0010":0 [ENABLED]
pad1: Source
-> "vi-output, imx219 31-0010":0 [ENABLED]
- entity 21: imx219 31-0010 (1 pad, 1 link)
device node name /dev/v4l-subdev3
pad0: Source
[fmt:SRGGB10_1X10/3280x2464 field:none colorspace:srgb]
-> "nvcsi--1":0 [ENABLED]
- entity 23: vi-output, imx219 31-0010 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "nvcsi--1":1 [ENABLED]
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=640, height=480, format=(string)UYVY’ ! nvvidconv ! nvegltransform ! nveglglessink -e
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120,000005
GST_ARGUS: PowerService: requested_clock_Hz=6048000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:04.245766040
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
dmesg | grep imx219
[ 3.580410] imx219 30-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.606567] imx219 31-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.578752] vi 54080000.vi: subdev imx219 30-0010 bound
[ 4.579471] vi 54080000.vi: subdev imx219 31-0010 bound
[ 345.055162] imx219 30-0010: imx219_power_on: power on
[ 345.118384] imx219 30-0010: imx219_set_gain: val: 71 (/16) [times], gain: 199
[ 345.118930] imx219 30-0010: imx219_set_exposure: val: 29999 [us], coarse_time: 1475 [lines]
[ 345.120128] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 345.177118] imx219 30-0010: imx219_power_off: power off
[ 345.177236] imx219 31-0010: imx219_power_on: power on
[ 345.294933] imx219 31-0010: imx219_power_off: power off
[ 345.295038] imx219 30-0010: imx219_power_on: power on
[ 345.318297] imx219 30-0010: imx219_power_off: power off
[ 345.318499] imx219 31-0010: imx219_power_on: power on
[ 345.341729] imx219 31-0010: imx219_power_off: power off
[ 345.344452] imx219 30-0010: imx219_power_on: power on
[ 345.367759] imx219 30-0010: imx219_power_off: power off
[ 345.368009] imx219 31-0010: imx219_power_on: power on
[ 345.391253] imx219 31-0010: imx219_power_off: power off
[ 345.415826] imx219 31-0010: imx219_power_on: power on
[ 345.439043] imx219 31-0010: imx219_power_off: power off
[ 345.439288] imx219 30-0010: imx219_power_on: power on
[ 345.462517] imx219 30-0010: imx219_power_off: power off
[ 345.462697] imx219 30-0010: imx219_power_on: power on
[ 345.485950] imx219 30-0010: imx219_power_off: power off
[ 345.486170] imx219 30-0010: imx219_power_on: power on
[ 345.509733] imx219 30-0010: imx219_power_off: power off
[ 345.546095] imx219 31-0010: imx219_power_on: power on
[ 345.569274] imx219 31-0010: imx219_power_off: power off
[ 345.569441] imx219 30-0010: imx219_power_on: power on
[ 345.592633] imx219 30-0010: imx219_power_off: power off
[ 345.592875] imx219 30-0010: imx219_power_on: power on
[ 345.616223] imx219 30-0010: imx219_power_off: power off
[ 345.616647] imx219 30-0010: imx219_power_on: power on
[ 345.640093] imx219 30-0010: imx219_power_off: power off
[ 345.920997] imx219 30-0010: imx219_power_on: power on
[ 345.944266] imx219 30-0010: imx219_set_frame_rate: val: 120000000e-6 [fps], frame_length: 409 [lines]
[ 345.945262] imx219 30-0010: imx219_set_gain: val: 16 (/16) [times], gain: 0
[ 345.945736] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 405 [lines]
[ 345.945740] imx219 30-0010: imx219_set_exposure: val: 8333 [us], coarse_time: 405 [lines]
[ 345.949261] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 345.950324] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 345.950329] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 345.994944] imx219 30-0010: imx219_set_gain: val: 16 (/16) [times], gain: 0
[ 345.995417] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 345.995422] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 345.996363] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 346.002546] imx219 30-0010: imx219_set_frame_rate: val: 120000000e-6 [fps], frame_length: 409 [lines]
[ 346.012095] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 346.240710] imx219 30-0010: imx219_set_gain: val: 20 (/16) [times], gain: 52
[ 346.275141] imx219 30-0010: imx219_set_gain: val: 24 (/16) [times], gain: 86
[ 346.309575] imx219 30-0010: imx219_set_gain: val: 27 (/16) [times], gain: 105
[ 346.343922] imx219 30-0010: imx219_set_gain: val: 30 (/16) [times], gain: 120
[ 346.344622] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.344627] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 346.378355] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.378361] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 346.412794] imx219 30-0010: imx219_set_gain: val: 31 (/16) [times], gain: 124
[ 346.413410] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.413416] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 346.447166] imx219 30-0010: imx219_set_gain: val: 32 (/16) [times], gain: 128
[ 346.447718] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.447723] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 346.481616] imx219 30-0010: imx219_set_gain: val: 34 (/16) [times], gain: 136
[ 346.516007] imx219 30-0010: imx219_set_gain: val: 37 (/16) [times], gain: 146
[ 346.550352] imx219 30-0010: imx219_set_gain: val: 39 (/16) [times], gain: 151
[ 346.584822] imx219 30-0010: imx219_set_gain: val: 41 (/16) [times], gain: 157
[ 346.619141] imx219 30-0010: imx219_set_gain: val: 43 (/16) [times], gain: 161
[ 346.653599] imx219 30-0010: imx219_set_gain: val: 44 (/16) [times], gain: 163
[ 346.654274] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.654279] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 346.687967] imx219 30-0010: imx219_set_gain: val: 45 (/16) [times], gain: 165
[ 346.688814] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.688824] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 346.722348] imx219 30-0010: imx219_set_gain: val: 47 (/16) [times], gain: 169
[ 346.722948] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.722953] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 346.756768] imx219 30-0010: imx219_set_gain: val: 48 (/16) [times], gain: 171
[ 346.757441] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.757447] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 346.791252] imx219 30-0010: imx219_set_gain: val: 50 (/16) [times], gain: 175
[ 346.791865] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 346.791871] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 346.825565] imx219 30-0010: imx219_set_gain: val: 56 (/16) [times], gain: 183
[ 346.826113] imx219 30-0010: imx219_set_exposure: val: 29999 [us], coarse_time: 1475 [lines]
[ 346.859983] imx219 30-0010: imx219_set_gain: val: 58 (/16) [times], gain: 186
[ 346.894372] imx219 30-0010: imx219_set_gain: val: 59 (/16) [times], gain: 187
[ 346.928807] imx219 30-0010: imx219_set_gain: val: 60 (/16) [times], gain: 188
[ 346.997648] imx219 30-0010: imx219_set_gain: val: 62 (/16) [times], gain: 190
[ 347.032011] imx219 30-0010: imx219_set_gain: val: 64 (/16) [times], gain: 192
[ 347.066606] imx219 30-0010: imx219_set_gain: val: 65 (/16) [times], gain: 193
[ 347.100776] imx219 30-0010: imx219_set_gain: val: 67 (/16) [times], gain: 195
[ 347.203991] imx219 30-0010: imx219_set_gain: val: 68 (/16) [times], gain: 196
[ 347.272904] imx219 30-0010: imx219_set_gain: val: 70 (/16) [times], gain: 198
[ 349.457148] imx219 30-0010: imx219_power_off: power off
gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=640, height=480, format=(string)UYVY’ ! nvvidconv ! nvegltransform ! nveglglessink -e
Using winsys: x11
Camera index = 1
Camera mode = 4
seconds to Run = 0
Waiting for EOS...
Execution ended after 0:00:06.491259268
GST_ARGUS:
dmesg | grep imx219
[ 404.698012] imx219 30-0010: imx219_power_on: power on
[ 404.767445] imx219 30-0010: imx219_set_gain: val: 70 (/16) [times], gain: 198
[ 404.767955] imx219 30-0010: imx219_set_exposure: val: 29999 [us], coarse_time: 1475 [lines]
[ 404.768937] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 404.825999] imx219 30-0010: imx219_power_off: power off
[ 404.826104] imx219 31-0010: imx219_power_on: power on
[ 404.943553] imx219 31-0010: imx219_power_off: power off
[ 404.943696] imx219 30-0010: imx219_power_on: power on
[ 404.966985] imx219 30-0010: imx219_power_off: power off
[ 404.967199] imx219 31-0010: imx219_power_on: power on
[ 404.990475] imx219 31-0010: imx219_power_off: power off
[ 404.994828] imx219 30-0010: imx219_power_on: power on
[ 405.018099] imx219 30-0010: imx219_power_off: power off
[ 405.018291] imx219 31-0010: imx219_power_on: power on
[ 405.041530] imx219 31-0010: imx219_power_off: power off
[ 405.061170] imx219 31-0010: imx219_power_on: power on
[ 405.084347] imx219 31-0010: imx219_power_off: power off
[ 405.084519] imx219 30-0010: imx219_power_on: power on
[ 405.107740] imx219 30-0010: imx219_power_off: power off
[ 405.107914] imx219 30-0010: imx219_power_on: power on
[ 405.131191] imx219 30-0010: imx219_power_off: power off
[ 405.131478] imx219 30-0010: imx219_power_on: power on
[ 405.154833] imx219 30-0010: imx219_power_off: power off
[ 405.185761] imx219 31-0010: imx219_power_on: power on
[ 405.208940] imx219 31-0010: imx219_power_off: power off
[ 405.209132] imx219 30-0010: imx219_power_on: power on
[ 405.232327] imx219 30-0010: imx219_power_off: power off
[ 405.232559] imx219 30-0010: imx219_power_on: power on
[ 405.255855] imx219 30-0010: imx219_power_off: power off
[ 405.256113] imx219 30-0010: imx219_power_on: power on
[ 405.279509] imx219 30-0010: imx219_power_off: power off
[ 406.634927] imx219 30-0010: imx219_power_on: power on
[ 406.658269] imx219 30-0010: imx219_set_frame_rate: val: 120000000e-6 [fps], frame_length: 409 [lines]
[ 406.659500] imx219 30-0010: imx219_set_gain: val: 16 (/16) [times], gain: 0
[ 406.659990] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 405 [lines]
[ 406.659994] imx219 30-0010: imx219_set_exposure: val: 8333 [us], coarse_time: 405 [lines]
[ 406.661240] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 406.664970] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 406.664976] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 406.711231] imx219 30-0010: imx219_set_gain: val: 16 (/16) [times], gain: 0
[ 406.711758] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 406.711763] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 406.713030] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 406.719540] imx219 30-0010: imx219_set_frame_rate: val: 120000000e-6 [fps], frame_length: 409 [lines]
[ 406.729097] imx219 30-0010: imx219_set_frame_rate: val: 30000001e-6 [fps], frame_length: 1639 [lines]
[ 406.957660] imx219 30-0010: imx219_set_gain: val: 20 (/16) [times], gain: 52
[ 406.992121] imx219 30-0010: imx219_set_gain: val: 24 (/16) [times], gain: 86
[ 407.026570] imx219 30-0010: imx219_set_gain: val: 27 (/16) [times], gain: 105
[ 407.030695] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.030700] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 407.060801] imx219 30-0010: imx219_set_gain: val: 30 (/16) [times], gain: 120
[ 407.095231] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.095237] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 407.129605] imx219 30-0010: imx219_set_gain: val: 31 (/16) [times], gain: 124
[ 407.130156] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.130162] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 407.164095] imx219 30-0010: imx219_set_gain: val: 32 (/16) [times], gain: 128
[ 407.198403] imx219 30-0010: imx219_set_gain: val: 34 (/16) [times], gain: 136
[ 407.199110] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.199116] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 407.232808] imx219 30-0010: imx219_set_gain: val: 36 (/16) [times], gain: 143
[ 407.267333] imx219 30-0010: imx219_set_gain: val: 39 (/16) [times], gain: 151
[ 407.268002] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.268006] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 407.301617] imx219 30-0010: imx219_set_gain: val: 41 (/16) [times], gain: 157
[ 407.302280] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.302285] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 407.336033] imx219 30-0010: imx219_set_gain: val: 42 (/16) [times], gain: 159
[ 407.370489] imx219 30-0010: imx219_set_gain: val: 43 (/16) [times], gain: 161
[ 407.404818] imx219 30-0010: imx219_set_gain: val: 44 (/16) [times], gain: 163
[ 407.405392] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.405398] imx219 30-0010: imx219_set_exposure: val: 33329 [us], coarse_time: 1635 [lines]
[ 407.439281] imx219 30-0010: imx219_set_gain: val: 45 (/16) [times], gain: 165
[ 407.473681] imx219 30-0010: imx219_set_gain: val: 47 (/16) [times], gain: 169
[ 407.474283] imx219 30-0010: imx219_set_exposure: exposure limited by frame_length: 1635 [lines]
[ 407.474288] imx219 30-0010: imx219_set_exposure: val: 33330 [us], coarse_time: 1635 [lines]
[ 407.508045] imx219 30-0010: imx219_set_gain: val: 49 (/16) [times], gain: 173
[ 407.542451] imx219 30-0010: imx219_set_gain: val: 55 (/16) [times], gain: 182
[ 407.543174] imx219 30-0010: imx219_set_exposure: val: 29999 [us], coarse_time: 1475 [lines]
[ 407.577000] imx219 30-0010: imx219_set_gain: val: 57 (/16) [times], gain: 185
[ 407.611325] imx219 30-0010: imx219_set_gain: val: 58 (/16) [times], gain: 186
[ 407.645651] imx219 30-0010: imx219_set_gain: val: 59 (/16) [times], gain: 187
[ 407.714799] imx219 30-0010: imx219_set_gain: val: 61 (/16) [times], gain: 189
[ 407.749189] imx219 30-0010: imx219_set_gain: val: 63 (/16) [times], gain: 191
[ 407.783269] imx219 30-0010: imx219_set_gain: val: 65 (/16) [times], gain: 193
[ 407.817726] imx219 30-0010: imx219_set_gain: val: 67 (/16) [times], gain: 195
[ 407.886538] imx219 30-0010: imx219_set_gain: val: 68 (/16) [times], gain: 196
[ 407.955411] imx219 30-0010: imx219_set_gain: val: 69 (/16) [times], gain: 197
[ 407.989699] imx219 30-0010: imx219_set_gain: val: 70 (/16) [times], gain: 198
[ 411.334176] imx219 30-0010: imx219_power_off: power off
Regards!
