Simultaneous cropping + scaling operations on the Nano and NGX
We have a use case that will require several cropping+scaling operations to occur in parallel (in order to minimize processing latency). I believe the scaling + cropping operation is handled by the VIC peripheral. Is this correct ?
From the data sheet, it is not clear how many crop + scale operations can be handled by the VIC peripheral in parallel.
And, what is the maximum number of nvvidconv gstreamer plugins that can be instantiated and run in parallel
Victor
Yes.
There should be no limitation in number of nvvidconv elements since low-level software stack handles the case. However, too many nvvidconv running in parallel may bring performance concern.
Please check gstreamer user guide for more sample pipelines:
https://developer.nvidia.com/embedded/dlc/l4t-accelerated-gstreamer-guide-32-2
