I have a USD with a very simple action graph. It contains this attribute:
/ActionGraph/OnImpulseEvent.state:enableImpulse
Since upgrading to 4.2 I can’t save the USD. If I try to simply delete the Action Graph so I can save everything else, I can’t do that either. This is the error message when I try to delete it:
File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.graph-1.140.0+10a4b5c0.lx64.r.cp310/omni/graph/core/_impl/object_lookup.py", line 383, in __attribute_from_info
specified_node = cls.node(node_name, graph)
File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.graph-1.140.0+10a4b5c0.lx64.r.cp310/omni/graph/core/_impl/object_lookup.py", line 221, in node
return __node_from_info(node_id)
File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.graph-1.140.0+10a4b5c0.lx64.r.cp310/omni/graph/core/_impl/object_lookup.py", line 214, in __node_from_info
raise og.OmniGraphValueError(f"Could not find OmniGraph node from node description '{node}' - {error}")
omni.graph.core._impl.errors.OmniGraphValueError: OmniGraphError: Could not find OmniGraph node from node description '/ActionGraph/OnImpulseEvent' - Node path '/ActionGraph/OnImpulseEvent' was not an OmniGraph node
The above exception was the direct cause of the following exception:
File "/home/user/workspaces/isaac_ros-dev//src/isaac_sim_scripts/simple_backups/start_robin.py", line 261, in <module>
main()
File "/home/user/workspaces/isaac_ros-dev//src/isaac_sim_scripts/simple_backups/start_robin.py", line 253, in main
og.Controller.attribute("/ActionGraph/OnImpulseEvent.state:enableImpulse"), True
File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.graph-1.140.0+10a4b5c0.lx64.r.cp310/omni/graph/core/_impl/object_lookup.py", line 424, in attribute
return __attribute_from_info(attribute_id)
File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.graph-1.140.0+10a4b5c0.lx64.r.cp310/omni/graph/core/_impl/object_lookup.py", line 415, in __attribute_from_info
raise og.OmniGraphError(
omni.graph.core._impl.errors.OmniGraphError: OmniGraphError: Failed trying to look up attribute with (/ActionGraph/OnImpulseEvent.state:enableImpulse, node=None, graph=None)
Here’s an image of the Action Graph.
