Single-Bit Corruption Detected by Device-Side Compare in Trivial Global Copy Kernel on RTX 3060 Ti (memcheck/racecheck clean)
I have a minimal CUDA repro where a pure global-memory copy kernel
out[i] = in[i];
shows nondeterministic mismatches across iterations.
Key isolation result: I compare dev_out vs dev_in on device and copy back only a tiny result struct (no D2H copy of the large output buffer).
I still get mismatches, so corruption appears to be on the GPU side (not just D2H/host RAM path).
System under test:
  • GPU: NVIDIA GeForce RTX 3060 Ti
  • Driver: 535.274.02
  • nvcc: CUDA 12.1 (V12.1.105)
Useful additional info:
  • Exact board partner SKU + VBIOS version
  • OS + motherboard + PCIe generation/link width
  • Whether behavior changes with different driver versions
  • Whether behavior changes with memory underclock / stock vs OC settings
Repro code (repro.cu)
#include <cuda_runtime.h>
#include <cstdint>
#include <cstdio>
#include <cstdlib>
namespace {
constexpr int kN = 500000;
constexpr int kIters = 500;
constexpr int kBlock = 256;
constexpr int kGrid = (kN + kBlock - 1) / kBlock;
void check_cuda(cudaError_t status, const char *ctx) {
  if (status != cudaSuccess) {
    std::fprintf(stderr, "%s failed: %s\n", ctx, cudaGetErrorString(status));
    std::exit(EXIT_FAILURE);
__global__ void copy64_kernel(const uint64_t *in, uint64_t *out) {
  const int i = blockIdx.x * blockDim.x + threadIdx.x;
  if (i < kN) out[i] = in[i];
struct DeviceCompareResult {
  int found;
  unsigned int idx;
  uint64_t in_val;
  uint64_t out_val;
  uint64_t xor_mask;
__global__ void find_mismatch_kernel(const uint64_t *in,
                                     const uint64_t *out,
                                     DeviceCompareResult *result) {
  if (i < kN) {
    const uint64_t a = in[i];
    const uint64_t b = out[i];
    if (a != b) {
      if (atomicCAS(&result->found, 0, 1) == 0) {
        result->idx = static_cast<unsigned int>(i);
        result->in_val = a;
        result->out_val = b;
        result->xor_mask = a ^ b;
}  // namespace
int main() {
  uint64_t *host_in = nullptr;
  check_cuda(cudaMallocHost(&host_in, static_cast<size_t>(kN) * sizeof(uint64_t)),
             "cudaMallocHost(host_in)");
  for (int i = 0; i < kN; ++i) {
    host_in[i] = static_cast<uint64_t>(i) * 0x9e3779b97f4a7c15ULL + 0x123456789ULL;
  uint64_t *dev_in = nullptr;
  uint64_t *dev_out = nullptr;
  DeviceCompareResult *dev_result = nullptr;
  check_cuda(cudaMalloc(&dev_in, static_cast<size_t>(kN) * sizeof(uint64_t)), "cudaMalloc(dev_in)");
  check_cuda(cudaMalloc(&dev_out, static_cast<size_t>(kN) * sizeof(uint64_t)), "cudaMalloc(dev_out)");
  check_cuda(cudaMalloc(&dev_result, sizeof(DeviceCompareResult)), "cudaMalloc(dev_result)");
  check_cuda(cudaMemcpy(dev_in,
                        host_in,
                        static_cast<size_t>(kN) * sizeof(uint64_t),
                        cudaMemcpyHostToDevice),
             "cudaMemcpy(dev_in <- host_in)");
  check_cuda(cudaDeviceSynchronize(), "cudaDeviceSynchronize(after H2D)");
  DeviceCompareResult host_result{};
  DeviceCompareResult reset_result{};
  reset_result.found = 0;
  reset_result.idx = 0xFFFFFFFFu;
  reset_result.in_val = 0;
  reset_result.out_val = 0;
  reset_result.xor_mask = 0;
  for (int iter = 0; iter < kIters; ++iter) {
    check_cuda(cudaMemcpy(dev_result,
                          &reset_result,
                          sizeof(DeviceCompareResult),
               "reset dev_result");
    copy64_kernel<<<kGrid, kBlock>>>(dev_in, dev_out);
    check_cuda(cudaGetLastError(), "copy64_kernel launch");
    find_mismatch_kernel<<<kGrid, kBlock>>>(dev_in, dev_out, dev_result);
    check_cuda(cudaGetLastError(), "find_mismatch_kernel launch");
    check_cuda(cudaDeviceSynchronize(), "compare sync");
    check_cuda(cudaMemcpy(&host_result,
                          dev_result,
                          cudaMemcpyDeviceToHost),
               "cudaMemcpy(host_result <- dev_result)");
    if (host_result.found != 0) {
      const uint64_t delta = host_result.out_val - host_result.in_val;
      std::printf("DEVICE_MISMATCH iter=%d first_diff=%u\n", iter, host_result.idx);
      std::printf("in =%016llx out=%016llx\n",
                  static_cast<unsigned long long>(host_result.in_val),
                  static_cast<unsigned long long>(host_result.out_val));
      std::printf("xor=%016llx delta=%016llx\n",
                  static_cast<unsigned long long>(host_result.xor_mask),
                  static_cast<unsigned long long>(delta));
      return 0;
  std::printf("No on-device mismatch in %d iterations.\n", kIters);
  return 0;
Build and run
nvcc -arch=sm_86 -O3 -lineinfo repro.cu -o repro
./repro
Typical output:
DEVICE_MISMATCH iter=2 first_diff=484151
in =c6105e3eaed52f0c out=c6105e1eaed52f0c
xor=0000002000000000 delta=ffffffe000000000
Additional checks
compute-sanitizer --tool memcheck ./repro
compute-sanitizer --tool racecheck ./repro
Both report clean summaries on my side (0 errors, 0 hazards), while mismatch still reproduces.
Question
Given this is now isolated as an on-device mismatch in a minimal deterministic copy path, is there any known driver/runtime issue here, or should this be treated as likely hardware instability/defect first?
Does it happen on the same bit (xor mask)?
Seems like a HW defect to me. Most probably GPU RAM or L2 cache.
You could copy to two locations at the same time (single read, 2 writes) and copy the same input to an output in different iterations. To deduce, whether there is an error when reading or writing or both. You could use patterns as data.
Different bit every time. I realize now, isn’t this not a defect but simply the nature of consumer GPUs not having ECC (error correcting code) support?
Bit errors in absence of ECC should be an extremely rare occurence. If it’s not, then you may have a defect in the RAM or in the traces & solderpads connecting the RAM.
Have you tried any 3rd party VRAM check utilities, such as CUDA GPU memtest download | SourceForge.net
Memtest passes. I also ran repro.cu on another similar GPU without issue.
I see now that random bit flips being “rare” means they should occur only once every few years, so that’s not what’s going on here.
Whatever the issue, I’ll simply rent another GPU.
GPUs may store pointers or data structures or the kernel program code.
Single-bit errors would possibly lead to crashes, definitely to Undefined Behavior.
Even on consumer GPUs doing 3D games it may be more serious than a single pixel error on the screen.
The Graphics Driver could at least have to be restarted.
