Single Bit Error Message on UART 1 instead of UART 0
According to this thread, a message will be printed on the debug UART port upon a single-bit error on ECC-DRAM. How can I get the message on another port, e.g. UART1?
It is not easy to test SBE so I would like to have a developer’s opinion and suggested DBT configuration before testing, rather than doing trial and error.
Hi peroxyacyl,
Are you using the devkit or custom board for TX2?
May I know what’s your use case to switch combined UART from UART0 to UART1?
Could you access UART0 to get those debug messages?
