Hi All, This document mentions (table 1, page 4) that a Orin could be configured as two concurrent EP (x8), via PCIe controllers C5 and C7 as indicated here.
In this context I would like to understand, how to configure Orin as EP under two different PCIe trees as indicated, in the attached picture? Where can I get details of the relevant BARs in C5, C7 to be programmed so that Orin can source / send data as two different EPs ?
HI Wayne,
I am not clear about starting with single EP case. I guess you are suggesting to get single EP working first. However we need to understand how dual EP will work at least on paper in order to plan the PCIe topology of the tree we are looking build.
Hi Wayne,
If Orin wants to send different set of data buffers to Device 1 and Device 2 (peer to peer) - How do I program the relevant BARs in C5 and C7 to transfer data to D1 and D2 ?
Hi Wayne,
My question is can we do concurrent p2p transfer between Orin<–> Device1 and Orin <–> Device 2 ? If so how do we program relevant BARs in C5 and C7?
What I am looking to do is to transfer data from Orin to device 1 and device 2 simultaneously. Device 1 and Device 2 belongs to different PCIe trees. So for that I would need to program Orin as EP in two different trees. How can I do that ?
