Hello nvidia team!
We are currently working with isaacsim and trying to give our users support to do robot sim with isaacsim. While going through docs we noticed that you deprecated SingleManipulator class, but investing further it seams that the path to the class i.e. namespaces was the deprecated part and not the class itself so its a bit confusing.
Concrete questions: are you deprecating the class SingleManipulator or the namespaces for it? Would you recommend using the SingleArticulation after RobotAssembler over SingleManipulator?
Kind Regards
Haris
Hello @haris.cavkic,
Thanks for posting in the Isaac ROS forum!
There are two separate changes here. If you trace this back to Isaac Sim 4.5, omni.isaac.manipulators was renamed to isaacsim.robot.manipulators. That rename was not itself a deprecation of SingleManipulator yet.
However, in Isaac Sim 6.0 and latest source, the isaacsim.robot.manipulators extension is now marked deprecated, so SingleManipulator lives in that extension, it remains available for compatibility but is not recommended for new workflows.
For new flow, please refer to isaacsim.robot.experimental.manipulators.examples for recommended alternatives and use the articulation-based APIs and the newer manipulator examples instead.
After using RobotAssembler, we would suggest you use an articulation-centric wrapper.
For Isaac Sim 6.0-style code, prefer isaacsim.core.experimental.prims.Articulation, as for the older Core API code, SingleArticulation is still a better choice than SingleManipulator.
Current replacement examples model robots like UR10/Franka as Articulation subclasses and keep end-effector/gripper logic explicit, rather than using SingleManipulator.
