Thats right. I’m attaching valgrind’s output.
==32379== Memcheck, a memory error detector
==32379== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==32379== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==32379== Command: ./nvsipl_camera --platform-config IMX390RGGBE3_200FOV_RGGB_CPHY_x2 --link-enable-masks 0x0001\ 0x0000\ 0x0000\ 0x0000 --enableRawOutput --showfps --nvsci
==32379== Parent PID: 13207
==32379==
==32379== Thread 4 DEVBLK_WORKER_0:
==32379== Invalid read of size 4
==32379== at 0x53F97AC: DevBlkCDII2CPgmrCreate (in /usr/lib/libnvsipl_devblk_cdi.so)
==32379== by 0x75E2D9B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so)
==32379== by 0x53F8F97: DevBlkCDIDeviceCreate (in /usr/lib/libnvsipl_devblk_cdi.so)
==32379== by 0x5412C17: nvsipl::CNvMDevice::CreateCDIDevice(void*, unsigned char) (in /usr/lib/libnvsipl_devblk_ddi.so)
==32379== by 0x50082C7: ??? (in /usr/lib/libnvsipl_devblk.so)
==32379== by 0x48FF4FB: ??? (in /usr/lib/libnvsipl.so)
==32379== by 0x491336F: ??? (in /usr/lib/libnvsipl.so)
==32379== by 0x4CECE93: ??? (in /usr/lib/aarch64-linux-gnu/libstdc++.so.6.0.25)
==32379== by 0x4BE0087: start_thread (pthread_create.c:463)
==32379== by 0x4F71FFB: thread_start (clone.S:78)
==32379== Address 0x705c7d4 is 0 bytes after a block of size 4 alloc'd
==32379== at 0x4847B0C: calloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==32379==
==32379== by 0x795461B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==32379== by 0x79399F7: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==32379== by 0x541383B: nvsipl::CNvMCameraModule::CreateCDIDevice(void*, unsigned char) (in /usr/lib/libnvsipl_devblk_ddi.so)
==32379== by 0x50083B3: ??? (in /usr/lib/libnvsipl_devblk.so)
==32379== Address 0x70aa034 is 0 bytes after a block of size 4 alloc'd
==32379==
==32379== by 0x795D0E7: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==32379== by 0x7939A0B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==32379== Address 0x70a86d4 is 0 bytes after a block of size 4 alloc'd
==32379==
ARM64 front end: load_store
disInstr(arm64): unhandled instruction 0xB820003E
disInstr(arm64): 1011'1000 0010'0000 0000'0000 0011'1110
==32379== valgrind: Unrecognised instruction at address 0x4b4b484.
==32379== at 0x4B4B484: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==32379== by 0x4AE96A7: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==32379== by 0x4B4C28F: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==32379== by 0x4BE7C77: __pthread_once_slow (pthread_once.c:116)
==32379== by 0x4B4C053: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==32379== by 0x4AE7F37: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==32379== by 0x400DDD7: _dl_fini (dl-fini.c:138)
==32379== by 0x4ED6E53: __run_exit_handlers (exit.c:108)
==32379== by 0x4ED6F8B: exit (exit.c:139)
==32379== by 0x4EC2723: (below main) (libc-start.c:344)
==32379== Your program just tried to execute an instruction that Valgrind
==32379== did not recognise. There are two possible reasons for this.
==32379== 1. Your program has a bug and erroneously jumped to a non-code
==32379== location. If you are running Memcheck and you just saw a
==32379== warning about a bad jump, it's probably your program's fault.
==32379== 2. The instruction is legitimate but Valgrind doesn't handle it,
==32379== i.e. it's Valgrind's fault. If you think this is the case or
==32379== you are not sure, please let us know and we'll try to fix it.
==32379== Either way, Valgrind will now raise a SIGILL signal which will
==32379== probably kill your program.
==32379==
==32379== Process terminating with default action of signal 4 (SIGILL)
==32379== Illegal opcode at address 0x4B4B484
==32379==
==32379== HEAP SUMMARY:
==32379== in use at exit: 13,318 bytes in 72 blocks
==32379== total heap usage: 210,184 allocs, 210,112 frees, 80,054,785 bytes allocated
==32379==
==32379== LEAK SUMMARY:
==32379== definitely lost: 208 bytes in 4 blocks
==32379== indirectly lost: 6,322 bytes in 60 blocks
==32379== possibly lost: 0 bytes in 0 blocks
==32379== still reachable: 6,788 bytes in 8 blocks
==32379== suppressed: 0 bytes in 0 blocks
==32379== Rerun with --leak-check=full to see details of leaked memory
==32379==
==32379== For counts of detected and suppressed errors, rerun with: -v
==32379== ERROR SUMMARY: 5 errors from 3 contexts (suppressed: 0 from 0)
Above is only valgrind output. I also can get both logs together:
==22433== Memcheck, a memory error detector
==22433== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==22433== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==22433== Command: ./nvsipl_camera --platform-config IMX390RGGBE3_200FOV_RGGB_CPHY_x2 --link-enable-masks 0x0001\ 0x0000\ 0x0000\ 0x0000 --enableRawOutput --showfps --nvsci
==22433==
==22433== Thread 4 DEVBLK_WORKER_0:
==22433== Invalid read of size 4
==22433== at 0x53F97AC: DevBlkCDII2CPgmrCreate (in /usr/lib/libnvsipl_devblk_cdi.so)
==22433== by 0x75E2D9B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so)
==22433== by 0x53F8F97: DevBlkCDIDeviceCreate (in /usr/lib/libnvsipl_devblk_cdi.so)
==22433== by 0x5412C17: nvsipl::CNvMDevice::CreateCDIDevice(void*, unsigned char) (in /usr/lib/libnvsipl_devblk_ddi.so)
==22433== by 0x50082C7: ??? (in /usr/lib/libnvsipl_devblk.so)
==22433== by 0x48FF4FB: ??? (in /usr/lib/libnvsipl.so)
==22433== by 0x491336F: ??? (in /usr/lib/libnvsipl.so)
==22433== by 0x4CECE93: ??? (in /usr/lib/aarch64-linux-gnu/libstdc++.so.6.0.25)
==22433== by 0x4BE0087: start_thread (pthread_create.c:463)
==22433== by 0x4F71FFB: thread_start (clone.S:78)
==22433== Address 0x705c7d4 is 0 bytes after a block of size 4 alloc'd
==22433== at 0x4847B0C: calloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==22433==
==22433== by 0x795461B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==22433== by 0x79399F7: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==22433== by 0x541383B: nvsipl::CNvMCameraModule::CreateCDIDevice(void*, unsigned char) (in /usr/lib/libnvsipl_devblk_ddi.so)
==22433== by 0x50083B3: ??? (in /usr/lib/libnvsipl_devblk.so)
==22433== Address 0x70aa034 is 0 bytes after a block of size 4 alloc'd
==22433==
==22433== by 0x795D0E7: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==22433== by 0x7939A0B: ??? (in /usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so)
==22433== Address 0x70a86d4 is 0 bytes after a block of size 4 alloc'd
==22433==
MAX96712: Revision 2 detected
MAX96712 Rev 2: Link 0: Tx amplitude 0x28, 0x68, 0xb3, 0x72, 0xd2
MAX96712 Rev 2 manual adaptation on the link 0 (31)
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX9295ASerializerDriver/cdi_max9295.c 1030
Module_id 30 Severity 2 : MAX9295: Device ID mismatch (expected, returned) 145 0
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.cpp 100
Module_id 30 Severity 2 : MAX9295: MAX9295CheckPresence(brdcstSerCDI) failed with NvMedia error 6
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.cpp 215
Module_id 30 Severity 2 : MAX96712: SetupAddressTranslations failed with SIPL error 2
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.cpp 46
Module_id 30 Severity 2 : MAX96712: TransportLink Init failed with SIPL error 2
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 711
Module_id 30 Severity 2 : Init failed for module on link 0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(2)
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 144
Module_id 30 Severity 2 : Device block action failed for block (action, block) 10
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 180
Module_id 30 Severity 2 : Failed to initialize device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 2
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 705: Deinit: Deinit() call in wrong state
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:0
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/utils/pwr_utils.cpp 464
Module_id 30 Severity 2 : nvccp_set_aggreg_pwr_off failed with status 2
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/CNvMMax96712.cpp 566
Module_id 30 Severity 2 : MAX96712: CNvMMax96712::DoSetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/ddi/DeserializerIF/CNvMDeserializer.cpp 42
Module_id 30 Severity 2 : CNvMDeserializer::SetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 845
Module_id 30 Severity 2 : Deserializer SetPower failed with SIPL error 127
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 40
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 244
Module_id 30 Severity 2 : Failed to deinit device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1016: Deinit: DeviceBlock manager fails to deinit
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 49: ~CNvMCamera: CNvMCamera object fails to deinit
==22433== valgrind: Unrecognised instruction at address 0x4b4b484.
==22433== at 0x4B4B484: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==22433== by 0x4AE96A7: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==22433== by 0x4B4C28F: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==22433== by 0x4BE7C77: __pthread_once_slow (pthread_once.c:116)
==22433== by 0x4B4C053: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==22433== by 0x4AE7F37: ??? (in /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0)
==22433== by 0x400DDD7: _dl_fini (dl-fini.c:138)
==22433== by 0x4ED6E53: __run_exit_handlers (exit.c:108)
==22433== by 0x4ED6F8B: exit (exit.c:139)
==22433== by 0x4EC2723: (below main) (libc-start.c:344)
==22433== Your program just tried to execute an instruction that Valgrind
==22433== did not recognise. There are two possible reasons for this.
==22433== 1. Your program has a bug and erroneously jumped to a non-code
==22433== location. If you are running Memcheck and you just saw a
==22433== warning about a bad jump, it's probably your program's fault.
==22433== 2. The instruction is legitimate but Valgrind doesn't handle it,
==22433== i.e. it's Valgrind's fault. If you think this is the case or
==22433== you are not sure, please let us know and we'll try to fix it.
==22433== Either way, Valgrind will now raise a SIGILL signal which will
==22433== probably kill your program.
==22433==
==22433== Process terminating with default action of signal 4 (SIGILL)
==22433== Illegal opcode at address 0x4B4B484
==22433==
==22433== HEAP SUMMARY:
==22433== in use at exit: 13,318 bytes in 72 blocks
==22433== total heap usage: 210,184 allocs, 210,112 frees, 80,054,785 bytes allocated
==22433==
==22433== LEAK SUMMARY:
==22433== definitely lost: 208 bytes in 4 blocks
==22433== indirectly lost: 6,322 bytes in 60 blocks
==22433== possibly lost: 0 bytes in 0 blocks
==22433== still reachable: 6,788 bytes in 8 blocks
==22433== suppressed: 0 bytes in 0 blocks
==22433== Rerun with --leak-check=full to see details of leaked memory
==22433==
==22433== For counts of detected and suppressed errors, rerun with: -v
==22433== ERROR SUMMARY: 5 errors from 3 contexts (suppressed: 0 from 0)
Illegal instruction
