I combine nvmedia sample: nvsipl/test/camera and dgpu/eglstream
Rewrite CComposite to queue buffer and post to eglstream.
I can receive and save to cuda.yuv.
but when I play yuv, it keeps blink.
Any suggest?
Please provide the following info:
Software Version
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Pegasus DevKit (E3550)
other
SDK Manager Version
1.4.0.7363
[*] other
Host Machine Version
[*] native Ubuntu 18.04
other
Dear @Denny.hsu ,
When I play YUV, it keeps blink
Have you stored the video the on consumer end and try replaying? How is the video feeding to eglsteam?
I found the cause:
"nvsipl_camera: Creating consumers
nvsipl_camera: Creating consumer Sensor4_Out1
nvsipl_camera: Compositor: Registered output:1 from link:0 of quad: 1 as id:13
nvsipl_camera: Creating INvSIPLClient
libnvsipl.so: CNvMClient.cpp: 24: Init: CNvMClient::Init
nvsipl_camera: Creating consumer Sensor4_Out2
nvsipl_camera: Compositor: Registered output:2 from link:0 of quad: 1 as id:14
Since I use “–link-enable-masks “0x0000 0x0001 0x0000 0x0000” -c SF3325_DPHY_x2”, then I will get two OnFrameAvailable, I should filter one result.
I though it will only one result for 0x0001, before, but seem not.
Why two frames in one camera?
Root cause: there is two output: ISP0 and ISP1, and there is only black frame in ISP1.
I send all frames, so it will blink.
Using “–disableISP1Output” will fix this issue.
