Hello out there.
I run into some problems with 3D-arrays and copying data into these arrays.
Sometimes it works well, sometimes it fails.
While debugging i found a not documented behavior for the dimensions for the arrays.
Here is my sample code:
[codebox]
texture<int4, 3, cudaReadModeElementType> tex;
cudaChannelFormatDesc chanDesc = cudaCreateChannelDesc(32, 32, 32, 32, cudaChannelFormatKindSigned);
cudaArray* d_tex;
cudaExtent ex = make_cudaExtent(w, h, d);
cudaMalloc3DArray(&d_tex, &chanDesc , ex );
int4* test_data;
cudaMalloc((void **)&test_data, sizeof(int4) * ex .width * ex .height * ex .depth);
cudaMemcpy3DParms copyParams = {0};
copyParams.srcPtr = make_cudaPitchedPtr((void *)test_data, sizeof(int4) * ex.width, ex.width, ex.height);
copyParams.dstArray = d_tex;
copyParams.kind = cudaMemcpyDeviceToDevice;
copyParams.extent = ex;
cudaMemcpy3D(©Params);
[/codebox]
After some test-runs I run this code in a loop with increasing numbers for each dimension.
Results:
If xdim = 4, 8, 12, 16, 20, 24, […] I got “cudaSuccess” for the copy operation, no matter how the other dimensions are.
Otherwise (if xdim != 4, 8, 12 […] ) only if the y dimension is 1 the copy operation works.
If ydim != 1 (no matter on z) the copying results in “cudaErrorInvalidValue”.
For example:
I can not copy data to an array with x=6, y=3, z=1
I can not copy data to an array with x=7, y=3, z=1
But i can copy data to an array with x=8, y=7, z=5
or with x=7, y=1, z=8
(The small dimension settings are just choosen for simplification, it seems there are the same problems for higher values)
Are there some known issues or restrictions I didnt found yet or am I just to stupid to get work correctly?
[My System]
MS Windows Vista 32bit
GeForce 9800 GTX+
Toolkit Version 2.1
SDK Version 2.1 Beta
