I try "import sklearn"command on jupyter notebook.
this command is worked on my Terminal.
I used Jetpack5.1.1 and use “pip install scikit-learn” to install.
ImportError Traceback (most recent call last)
File ~/.local/lib/python3.8/site-packages/sklearn/__check_build/init.py:45
44 try:
—> 45 from ._check_build import check_build # noqa
46 except ImportError as e:
ImportError: /home/keita/.local/lib/python3.8/site-packages/sklearn/__check_build/…/…/scikit_learn.libs/libgomp-d22c30c5.so.1.0.0: cannot allocate memory in static TLS block
During handling of the above exception, another exception occurred:
Cell In[10], line 1
----> 1 import sklearn
File ~/.local/lib/python3.8/site-packages/sklearn/init.py:79
68 sys.stderr.write(“Partial import of sklearn during the build process.\n”)
69 # We are not importing the rest of scikit-learn during the build
70 # process, as it may not be compiled yet
71 else:
77 # later is linked to the OpenMP runtime to make it possible to introspect
78 # it and importing it first would fail if the OpenMP dll cannot be found.
—> 79 from . import (
80 __check_build, # noqa: F401
81 _distributor_init, # noqa: F401
82 )
83 from .base import clone
84 from .utils._show_versions import show_versions
File ~/.local/lib/python3.8/site-packages/sklearn/__check_build/init.py:47
—> 47 raise_build_error(e)
File ~/.local/lib/python3.8/site-packages/sklearn/__check_build/init.py:31, in raise_build_error(e)
29 else:
30 dir_content.append(filename + “\n”)
—> 31 raise ImportError(“”“%s
32 ___________________________________________________________________________
33 Contents of %s:
34 %s
35 ___________________________________________________________________________
36 It seems that scikit-learn has not been built correctly.
37
38 If you have installed scikit-learn from source, please do not forget
39 to build the package before using it: run python setup.py install
or
40 make
in the source directory.
41 %s”“” % (e, local_dir, “”.join(dir_content).strip(), msg))
Contents of /home/keita/.local/lib/python3.8/site-packages/sklearn/_check_build:
init.py check_build.cpython-38-aarch64-linux-gnu.so__pycache
or
make
If you have used an installer, please check that it is suited for your
Python version, your operating system and your platform.
