[skrl:INFO] Seed: 1521575493
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.isaac.kit.app_framework'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Starting kit application with the following args: ['/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts', '--ext-folder', '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/apps', '--/physics/cudaDevice=0', '--portable', '--no-window']
Passing the following args to the base kit application: []
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[Info] [carb] Logging to file: /home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/logs/Kit/Isaac-Sim/2022.2/kit_20230830_202343.log
2023-08-30 19:23:43 [20ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar' or '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar/config'
2023-08-30 19:23:43 [20ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar' or '/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar/config'
[0.191s] [ext: omni.stats-0.0.0] startup
[0.226s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.231s] [ext: omni.assets.plugins-0.0.0] startup
[0.234s] [ext: omni.gpu_foundation-0.0.0] startup
[0.258s] [ext: carb.windowing.plugins-1.0.0] startup
[0.265s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-08-30 19:23:45 [1,893ms] [Warning] [carb.graphics-vulkan.plugin] No command queue family supports flags: 0x100, queue type: 3. No queues of this type will be created
2023-08-30 19:23:45 [1,908ms] [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 0. Skipping this device.
| Driver Version: 535.86.05 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | AMD Unknown (RADV RENOIR) | | | 5468 MB | 1002 | 0 |
| | | | | | 1638 | 00000000.. |
| 1 | NVIDIA GeForce RTX 3060 Laptop.. | Yes: 0 | | 6144 MB | 10de | 0 |
| | | | | | 2520 | 8aea3097.. |
| OS: Linux marty-Blade-14-RZ09-0370, Version: 6.2.0-26-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 9 5900HX with Radeon Graphics | Cores: Unknown | Logical: 16
| Total Memory (MB): 15380 | Free Memory: 3364
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 11 items in /sys/kernel/iommu_groups/.
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] !!!!! Local system validation failed! Incorrect configuration detected.
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] Summary below. Details above.
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] - ECC: OK
2023-08-30 19:23:45 [1,957ms] [Warning] [gpu.foundation.plugin] - IOMMU: FAILED
[2.220s] [ext: omni.kit.pipapi-0.0.0] startup
[2.239s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.243s] [ext: omni.kit.loop-isaac-1.0.0] startup
[2.244s] [ext: omni.kit.async_engine-0.0.0] startup
[2.245s] [ext: omni.kit.test-0.0.0] startup
[2.278s] [ext: omni.usd.config-1.0.0] startup
[2.285s] [ext: omni.usd.libs-1.0.0] startup
[2.544s] [ext: omni.isaac.core_archive-2.0.1] startup
[2.556s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[2.558s] [ext: omni.isaac.ml_archive-1.1.0] startup
[2.559s] [ext: omni.client-0.1.1] startup
[2.579s] [ext: omni.appwindow-1.0.1] startup
[2.582s] [ext: omni.kit.renderer.core-0.0.0] startup
[2.589s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.593s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[2.651s] [ext: carb.audio-0.1.0] startup
[2.656s] [ext: omni.ui-2.14.4] startup
[2.715s] [ext: omni.uiaudio-1.0.0] startup
[2.717s] [ext: omni.kit.mainwindow-1.0.0] startup
[2.719s] [ext: omni.kit.uiapp-0.0.0] startup
[2.719s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.773s] [ext: omni.usd.schema.isaac-1.1.0] startup
[2.794s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.807s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.819s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[2.831s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.843s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.851s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.916s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.923s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[2.925s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.961s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.962s] [ext: omni.timeline-1.0.5] startup
[2.964s] [ext: omni.kit.search_core-1.0.2] startup
[2.966s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[2.976s] [ext: omni.kit.widget.path_field-2.0.4] startup
[2.983s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[3.000s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[3.002s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[3.008s] [ext: omni.kit.actions.core-1.0.0] startup
[3.012s] [ext: omni.usd.core-1.0.4] startup
[3.014s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[3.016s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[3.018s] [ext: omni.kit.commands-1.4.5] startup
[3.024s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[3.042s] [ext: omni.kit.notification_manager-1.0.5] startup
[3.045s] [ext: omni.usd-1.6.30] startup
[3.104s] [ext: omni.kit.widget.versioning-1.3.8] startup
[3.107s] [ext: omni.iray.libs-0.0.0] startup
[3.148s] [ext: omni.kit.window.filepicker-2.7.15] startup
[3.211s] [ext: omni.mdl.neuraylib-0.1.0] startup
[3.216s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[3.218s] [ext: omni.kit.window.file_importer-1.0.10] startup
[3.219s] [ext: omni.mdl-0.1.0] startup
[3.241s] [ext: omni.kit.usd.layers-2.0.11] startup
[3.253s] [ext: omni.kit.menu.utils-1.4.7] startup
[3.266s] [ext: omni.kit.material.library-1.3.21] startup
[3.272s] [ext: omni.kit.menu.create-1.0.8] startup
[3.274s] [ext: omni.kit.clipboard-1.0.0] startup
[3.275s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[3.364s] [ext: omni.kit.context_menu-1.5.12] startup
[3.368s] [ext: omni.kit.window.extensions-1.1.1] startup
[3.375s] [ext: omni.inspect-1.0.1] startup
[3.380s] [ext: omni.kit.window.property-1.8.2] startup
[3.383s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[3.388s] [ext: omni.graph.core-2.65.4] startup
[3.394s] [ext: omni.isaac.version-1.0.0] startup
[3.396s] [ext: omni.kit.stage_templates-1.1.13] startup
[3.398s] [ext: omni.kit.usd_undo-0.1.2] startup
[3.399s] [ext: omni.graph.tools-1.17.2] startup
[3.419s] [ext: omni.ui.scene-1.5.18] startup
[3.428s] [ext: omni.graph-1.50.2] startup
[3.476s] [ext: omni.ui_query-1.1.1] startup
[3.478s] [ext: omni.volume-0.1.0] startup
[3.483s] [ext: omni.kit.ui_test-1.2.9] startup
[3.485s] [ext: omni.hydra.rtx-0.1.0] startup
[3.507s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[3.509s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[3.513s] [ext: omni.debugdraw-0.1.1] startup
[3.518s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[3.522s] [ext: omni.hydra.pxr-1.1.2] startup
[3.529s] [ext: omni.activity.core-1.0.1] startup
[3.533s] [ext: omni.kit.hydra_texture-1.0.11] startup
[3.540s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[3.547s] [ext: omni.kit.viewport.registry-104.0.2] startup
[3.548s] [ext: omni.kit.widget.viewport-104.1.16] startup
[3.551s] [ext: omni.kit.window.drop_support-1.0.1] startup
[3.552s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[3.554s] [ext: omni.hydra.engine.stats-1.0.0] startup
[3.558s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[3.559s] [ext: omni.kit.window.file-1.3.32] startup
[3.563s] [ext: omni.kit.viewport.window-104.1.23] startup
[3.589s] [ext: omni.kit.widget.settings-1.0.1] startup
[3.591s] [ext: omni.kit.widget.stage-2.7.24] startup
[3.596s] [ext: omni.kit.window.content_browser-2.6.8] startup
[3.613s] [ext: omni.kit.viewport.utility-1.0.14] startup
[3.615s] [ext: omni.kit.window.preferences-1.3.8] startup
[3.640s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[3.644s] [ext: omni.kit.widget.prompt-1.0.5] startup
[3.645s] [ext: omni.kit.property.usd-3.18.17] startup
[3.656s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[3.658s] [ext: omni.graph.ui-1.24.2] startup
[3.699s] [ext: omni.physics.tensors-0.1.0] startup
[3.709s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[3.711s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[3.712s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[3.716s] [ext: omni.graph.window.core-1.43.3] startup
[3.725s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[3.726s] [ext: omni.kvdb-0.0.0] startup
[3.731s] [ext: omni.usdphysics-104.2.4-5.1] startup
[3.734s] [ext: omni.localcache-0.0.0] startup
[3.737s] [ext: omni.graph.scriptnode-0.10.0] startup
[3.741s] [ext: omni.physx-104.2.4-5.1] startup
[3.778s] [ext: omni.command.usd-1.0.2] startup
[3.781s] [ext: omni.physx.tensors-0.1.0] startup
[3.789s] [ext: omni.graph.window.generic-1.3.15] startup
[3.792s] [ext: omni.kit.browser.core-2.2.2] startup
[3.798s] [ext: omni.graph.action-1.31.1] startup
[3.880s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[3.885s] [ext: omni.kit.window.cursor-1.1.1] startup
[3.886s] [ext: omni.kit.widget.spinner-1.0.4] startup
[3.888s] [ext: omni.kit.browser.sample-1.2.5] startup
[3.891s] [ext: omni.graph.nodes-1.48.3] startup
[3.913s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[3.935s] [ext: omni.kit.numpy.common-0.1.0] startup
[3.938s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.2
Devices:
"cpu" | x86_64
"cuda:0" | NVIDIA GeForce RTX 3060 Laptop GPU (sm_86)
Kernel cache: /home/marty/.cache/warp/0.6.3
[4.158s] [ext: omni.syntheticdata-0.2.4] startup
2023-08-30 19:23:47 [4,161ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[4.180s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[4.195s] [ext: omni.replicator.core-1.7.8] startup
2023-08-30 19:23:47 [4,210ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[4.368s] [ext: omni.isaac.core-1.46.3] startup
[4.458s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[4.460s] [ext: omni.isaac.core_nodes-0.23.2] startup
[4.569s] [ext: omni.isaac.cloner-0.4.1] startup
[4.570s] [ext: omni.isaac.lula-1.2.1] startup
[4.591s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[4.598s] [ext: omni.isaac.debug_draw-0.2.3] startup
[4.606s] [ext: omni.isaac.gym-0.3.3] startup
[4.606s] [ext: omni.graph.window.action-1.5.5] startup
[4.608s] [ext: omni.isaac.ui-0.8.0] startup
[4.613s] [ext: usdrt.scenegraph-4.3.2] startup
[4.638s] [ext: omni.isaac.motion_planning-0.2.2] startup
[4.656s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[4.663s] [ext: omni.isaac.range_sensor-0.8.1] startup
[4.698s] [ext: omni.isaac.motion_generation-4.5.6] startup
[4.705s] [ext: omni.isaac.manipulators-1.1.0] startup
[4.708s] [ext: omni.isaac.sensor-5.6.3] startup
2023-08-30 19:23:48 [4,695ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[4.786s] [ext: omni.isaac.dofbot-0.3.0] startup
[4.788s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[4.800s] [ext: omni.isaac.quadruped-1.3.0] startup
[5.128s] [ext: omni.isaac.scene_blox-0.1.0] startup
[5.129s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[5.132s] [ext: omni.isaac.universal_robots-0.3.2] startup
[5.133s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-08-30 19:23:48 [5,120ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[5.134s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[5.137s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[5.145s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[5.155s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[5.157s] [ext: omni.kit.widget.layers-1.6.11] startup
[5.169s] [ext: omni.kit.selection-0.1.0] startup
[5.171s] [ext: omni.isaac.mjcf-0.3.1] startup
[5.185s] [ext: omni.kit.window.stage-2.3.12] startup
[5.189s] [ext: omni.kit.property.layer-1.1.4] startup
[5.191s] [ext: omni.kit.menu.edit-1.1.6] startup
[5.194s] [ext: omni.kit.menu.file-1.1.4] startup
[5.196s] [ext: omni.kit.menu.stage-1.2.1] startup
[5.198s] [ext: omni.kit.property.audio-1.0.6] startup
[5.199s] [ext: omni.kit.property.camera-1.0.3] startup
[5.201s] [ext: omni.kit.property.geometry-1.2.2] startup
[5.203s] [ext: omni.kit.property.light-1.0.6] startup
[5.205s] [ext: omni.hydra.scene_api-0.1.1] startup
[5.213s] [ext: omni.kit.property.material-1.8.19] startup
[5.216s] [ext: omni.kit.property.render-1.1.0] startup
[5.217s] [ext: omni.kit.property.skel-1.0.1] startup
[5.219s] [ext: omni.kit.property.transform-1.3.5] startup
[5.224s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[5.226s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[5.234s] [ext: omni.kit.profiler.window-2.0.5] startup
[5.437s] [ext: omni.kit.property.bundle-1.2.6] startup
[5.439s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[5.441s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[5.447s] [ext: omni.kit.window.toolbar-1.4.0] startup
[5.450s] [ext: omni.kit.property.isaac-0.2.0] startup
[5.452s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[5.455s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[5.455s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[5.461s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[5.461s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[5.463s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[5.468s] [ext: omni.rtx.window.settings-0.6.2] startup
[5.475s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[5.481s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[5.484s] [ext: omni.physx.commands-104.2.4-5.1] startup
[5.488s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[5.490s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[5.492s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[5.492s] [ext: omni.physx.ui-104.2.4-5.1] startup
[5.536s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[5.539s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[5.539s] [ext: omni.kit.viewport.ready-1.0.2] startup
[5.540s] [ext: omni.physx.demos-104.2.4-5.1] startup
[5.543s] [ext: omni.kit.property.physx-0.1.0] startup
[5.585s] [ext: omni.isaac.urdf-0.5.9] startup
[5.613s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[5.614s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[5.632s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[5.647s] [ext: omni.physx.cct-104.2.4-5.1] startup
[5.656s] [ext: omni.physx.camera-104.2.4-5.1] startup
[5.665s] [ext: omni.kit.actions.window-1.1.0] startup
[5.671s] [ext: omni.kit.window.commands-0.2.4] startup
[5.673s] [ext: omni.kit.window.console-0.2.3] startup
[5.684s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[5.684s] [ext: omni.graph.bundle.action-1.3.0] startup
[5.684s] [ext: omni.kit.window.script_editor-1.7.2] startup
[5.688s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[5.695s] [ext: omni.kit.window.status_bar-0.1.5] startup
[5.701s] [ext: omni.kit.window.title-1.1.2] startup
[5.702s] [ext: omni.replicator.composer-1.2.10] startup
[5.708s] [ext: omni.replicator.isaac-1.7.4] startup
[5.726s] [ext: omni.resourcemonitor-1.0.0] startup
[5.734s] [ext: omni.rtx.settings.core-0.5.8] startup
[5.739s] [ext: omni.isaac.franka-0.4.0] startup
[5.741s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[5.741s] [ext: semantics.schema.editor-0.3.3] startup
[5.745s] [ext: omni.kit.widget.live-2.0.3] startup
[5.747s] [ext: omni.isaac.utils-0.2.4] startup
[5.752s] [ext: omni.isaac.kit-1.4.1] startup
[5.753s] [ext: omni.isaac.cortex-0.3.2] startup
[5.753s] [ext: omni.kit.window.stats-0.1.2] startup
[5.755s] [ext: omni.isaac.sim.python-2022.2.1] startup
[5.756s] Simulation App Starting
/home/marty/.local/share/ov/pkg/isaac_sim-2022.2.1/python.sh: line 41: 83899 Killed $python_exe "$@" $args
There was an error running python
Is that what you meant by logs? Right now i ran it headless as you sent me, still gave this error
