Hi
From Jetson TX2 docs and descriptions from NVIDIA Jetson Linux Driver Package Software Features:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/power_management_tx2_32.html#wwpID0E0PT0HA
I deduced the following result:
There are two different sleep modes:
- Sleep mode
- Deep Sleep mode (SC7)
-Sleep mode can be entered by a short press of the power button, or a press of the Sleep (VOL DOWN) button. The system will awakes from the sleep mode with a short press of the power button.
-Deep Sleep mode (SC7) can be initiated using the following command:
sudo systemctl suspend
and be exited using wake capable pins listed in table 11 of the Jetson TX2 product design guide file, or other mechanisms listed in the following table:
1- Is this correct?
2- Is there any sleep (low power) mode that the systems power consumption goes below, for example, 200 mW, but yet it can listen to the CAN bus and wake from sleep? I know there is a CAN_WAKE signal, but it will respond to any CAN message on the bus. I seek for a state that the system be in low power mode, and listen to the CAN bus, and if a specific CAN message was received, it awake from the sleep.
