Hi!
AFAIK the TK1 (GK20A arch.) has compute capability 3.2 which is said to be “roughly the same” as CC 3.5.
Anyone know where I might find the exact specs on this?
I know the SM differs in that the register file is smaller (half the size).
-Any other known differences?
-Has anyone tested atomic performance?
/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GK20A"
CUDA Driver Version / Runtime Version 6.0 / 6.0
CUDA Capability Major/Minor version number: 3.2
Total amount of global memory: 1746 MBytes (1831051264 bytes)
( 1) Multiprocessors, (192) CUDA Cores/MP: 192 CUDA Cores
GPU Clock rate: 960 MHz (0.96 GHz)
Memory Clock rate: 924 Mhz
Memory Bus Width: 64-bit
L2 Cache Size: 131072 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: No
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
