hi,
glVertex2f() needs to be called AFTER glTexCoord2f. In the BoxFilter SDK 2.0 sample this is done wrong, leading to the following effect: The first image rendered will appear completely distorted.
Repro case:
This can be seen nicely in the device emulation mode with the BoxFilter sample, where rendering a single frame takes relatively long. Part of the image is missing, the lower image is distorted.
Quoting the OpenGL specification
" DESCRIPTION
glVertex commands are used within glBegin/glEnd pairs to
specify point, line, and polygon vertices. The current
color, normal, and texture coordinates are associated with
the vertex when glVertex is called. "
So please define the texture coordinate before the vertex. Maybe the texcoord order to achieve an correctly oriented “lena” image also has to be adjusted. You figure that out. ;)
This could also affect other SDK samples using textured quads. I haven’t checked them all.
Christian
