I think it is much mor simple to just encode the video by myself :-)
And this allows me to generate a perfectly looping video even without writing duplicated files to disk…
Perhaps you can integrate this feature to one of the next versions of the capture extension…
import os
import threading
import carb
from omni.kit.capture.viewport.helper import get_num_pattern_file_path
try:
from video_encoding import get_video_encoding_interface
except ImportError:
get_video_encoding_interface = lambda: None
g_video_encoding_api = get_video_encoding_interface()
def generateVideo(video_name, frames_dir, filename_prefix, filename_num_pattern,start_number, total_frames, frame_rate, image_type=“.png”, loop=False, holdStart=0.0, holdEnd=0.0):
carb.log_warn(f"Using videoencoding plugin to encode video ({video_name})")
global g_video_encoding_api
if g_video_encoding_api is None:
carb.log_warn("Video encoding api not available; cannot encode video.")
return False
next_frame = start_number
frame_count = 0
_frame_filenames = []
while True:
frame_path = get_num_pattern_file_path(frames_dir,filename_prefix,filename_num_pattern,next_frame,image_type)
if os.path.isfile(frame_path) and os.access(frame_path, os.R_OK):
_frame_filenames.append(frame_path)
next_frame += 1
frame_count += 1
if frame_count == total_frames:
break
else:
break
carb.log_warn(f"Found {len(_frame_filenames)} frames to encode.")
if len(_frame_filenames) == 0:
carb.log_warn(f"No frames to encode.")
return False
finalFrameCount = len(_frame_filenames)
if loop:
finalFrameCount *= 2
if holdEnd > 0:
finalFrameCount += int(24 * holdEnd)
if holdStart > 0:
finalFrameCount += int(24 * holdStart)
if not g_video_encoding_api.start_encoding(video_name, frame_rate, finalFrameCount, True):
carb.log_warn(f"videoencoding plug failed to start encoding.")
return False
try:
for frame_filename in _frame_filenames:
g_video_encoding_api.encode_next_frame_from_file(frame_filename)
if loop:
if holdEnd > 0:
for frameIndex in range(0, int(24 * holdEnd)):
g_video_encoding_api.encode_next_frame_from_file(_frame_filenames[len(_frame_filenames) - 1])
for frame_filename in reversed(_frame_filenames):
if holdStart > 0:
for frameIndex in range(0, int(24 * holdStart)):
g_video_encoding_api.encode_next_frame_from_file(_frame_filenames[0])
except:
import traceback
carb.log_warn(traceback.format_exc())
finally:
g_video_encoding_api.finalize_encoding()
carb.log_warn(f"videoencoding done")
generateVideo(“D:/Temp/MyVideo.mp4”, “D:/Users/c.Bickmeier/Documents/Kit/shared/capture/Capture_frames”, “Capture”, “.####”, 40, 20, 24, loop=True, holdStart=1, holdEnd=1)
