I wanted to use the VPI library for the tracker in the specific KLT Feature Tracker, using the algorithm I realized that the maximum size of the Bounding Box is 64x64, I work with 2560x1440 images and every object I select has a big bbox and then it is lost immediately in the next frame, is there a way to be able to use bigger bounding boxes or track bigger objects?
Salvatore
