Smart Record can record audio in DeepStream 6.0.1, but can't record audio in DeepStream 6.1.1
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.1.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) bugs
SmartRecord can record audio in DeepStream 6.0.1,
but can’t record audio in DeepStream 6.1.1
How to reproduce the issue
prepare rtsp
docker run --rm --name rtspserver -itd --network=host -e RTSP_PROTOCOLS=tcp aler9/rtsp-simple-server
ffmpeg -re -stream_loop -1 -i sample_1080p_h264.mp4 -c:v libx264 -r 30 -bf 0 -g 1 -c:a copy -f rtsp -rtsp_transport tcp rtsp://localhost:8554/mystream
DS 6.0.1 works
nvidia-docker run --rm -it nvcr.io/nvidia/deepstream:6.0.1-triton
cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-testsr/
CUDA_VER=11.4 make -j
URI=rtsp://127.0.0.1:8554/mystream
./deepstream-testsr-app $URI --bbox-enable=0 --enc-type=1 --sink-type=1 --sr-mode=0
Log is like below and the output mp4 contains video+audio
Running...
In cb_newpad
In cb_newpad
Recording started..
Recording done.
Recording started..
DS6.1.1 try1 does not work
nvidia-docker run --rm -it nvcr.io/nvidia/deepstream:6.1.1-triton
CUDA_VER=11.7 make -j
The log is like below.
Running...
Recording started..
In cb_newpad
In cb_newpad
ERROR from element audio-parser-pre-recordbin: Your GStreamer installation is missing a plug-in.
Error details: gstparsebin.c(3486): gst_parse_bin_expose (): /GstPipeline:dstest-sr-pipeline/GstParseBin:audio-parser-pre-recordbin:
no suitable plugins found:
Missing parser: MPEG-4 AAC (audio/mpeg, mpegversion=(int)4, stream-format=(string)raw, codec_data=(buffer)1190)
Returned, stopping playback
Deleting pipeline
DS 6.1.1 try2 does not work (apt install then run the binary)
apt-get install --reinstall --no-install-recommends -y libavcodec58 libavcodec-dev libavformat58 libavformat-dev libavutil56 libavutil-dev gstreamer1.0-libav
The output mp4 contains video but does not contain audio.
Running...
In cb_newpad
In cb_newpad
Recording started..
Recording done.
** ERROR: <RunUserCallback:207>: No video stream found
** ERROR: <RunUserCallback:212>: No audio stream found
Recording started..
DS 6.1.1 try3
I changed container type from mp4 to mkv but the output mkv does not contain audio.
Running...
In cb_newpad
In cb_newpad
Recording started..
Recording done.
Recording started..
Could you update the DeepStream Version to 6.2 and have a try?
@yuweiw
I tested DS6.2 and could not record (tried try1/try2).
ds62-try2.txt (3.8 KB)
ds62-try1.txt (5.1 KB)
# ./deepstream-testsr-app $URI --bbox-enable=0 --enc-type=1 --sink-type=1 --sr-mode=0
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:01.911: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:01.959: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:02.018: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:02.107: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:02.111: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:44): GStreamer-WARNING **: 00:10:02.131: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
I found that
  • The log tell that it failed to load plugin libmpg123.so.0, libmpeg2encpp-2.1.so.0, libmpeg2.so.0, libmpg123.so.0, libavcodec.so.58due to missing shared library
  • smartrecord tells missing parser:Missing parser: MPEG-4 AAC (audio/mpeg, mpegversion=(int)4, stream-format=(string)raw, codec_data=(buffer)1190)
  • I could not load mpegaudioparse by gst-inspect-1.0
After I run below apt command, video+audio record sometimes success and sometimes fail
apt install --reinstall gstreamer1.0-plugins-good
apt install --reinstall libvpx6 libx264-155 libx265-179 libmpg123-0 libmpeg2-4 libmpeg2encpp-2.1-0
ds62-ok.txt (2.0 KB)
ds62-ng-sometimes.txt (2.1 KB)
This behavior is the same in DespStream6.1.1, after the above command.
Error log is like below (See attached file for detail). This happens when cb_newpad_audio_parsebin() try to link to asink of recordbin.
(deepstream-testsr-app:1438): GStreamer-CRITICAL **: 01:45:09.635: gst_pad_link_full: assertion 'GST_IS_PAD (sinkpad)' failed
Elements not linked. Exiting.
My question is that
  1. Is it OK to reinstall gstreamer1.0-plugins-good? (DeepStream may be intented to use modified version of gst-plugins-good)
  2. Is missing library in container considered a bug?
  3. How to fix “Elements not linked” error? I suspect it’s a problem inside recordbin.
  4. When record success, I see the below warning. What is it?
 WARN: <audio_queue_src_pad_probe:301>: Invalid PTS found in stream. Stream recorded by Smart Record might have issues
“Elements not linked” often happens in DeepStream 6.2 rather than 6.1.1
GST_DEBUG=3 shows some warning.
Running...
Recording started..
In cb_newpad
0:00:08.154329034   421 0x56467c0a6de0 FIXME               basesink gstbasesink.c:3246:gst_base_sink_default_event:<nvvideo-renderer> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.162414819   421 0x56467c0a69e0 FIXME               basesink gstbasesink.c:3246:gst_base_sink_default_event:<src_filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.162549910   421 0x56467c0a69e0 WARN                   qtmux gstqtmux.c:2981:gst_qt_mux_start_file:<mux_elem0> Robust muxing requires reserved-moov-update-period to be set
In cb_newpad
cb_newpad_audio_parsebin() Link audio start
0:00:08.262805423   421 0x7f79b4062060 WARN                   qtmux gstqtmux.c:6367:gst_qt_mux_request_new_pad:<mux_elem0> Not providing request pad after stream start.
(deepstream-testsr-app:421): GStreamer-CRITICAL **: 02:58:56.330: gst_pad_link_full: assertion 'GST_IS_PAD (sinkpad)' failed
OK, I can repro your problem in my Deepstream 6.2 env. We’ll check and fix it. Please look forward to the next version. Thanks
