I’m using smart record in my own app based on deepstream-test3 and copying the way that deepstream-app uses it. i.e. with rtsp and tee off before decoding.
I use an event detection to trigger smart record. A duration of 30 seconds.
I find that recorded files seem to freeze every couple of seconds for a few seconds each time. It makes them pretty much useless as you lose a lot of movement in the few seconds that they are frozen. I don’t see any errors or warnings about buffers being dropped on the console.
My approx pipeline is as follows:
rtspsrc ! rtph265depay ! h265parse ! tee ! queue ! decodebin ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM)"
\ ctx->recordBin
\ ctx->recordBin
\ ctx->recordBin
\ ctx->recordBin
All piped into ! streammux ! nvinfer ! tracker ! nvdsanalytics ! tiler ! fakesink.
Note this is just the same way that deepstream-app is linking the elements when using smart record.
If you can provide me a way… I can send you some sample files.
• Hardware Platform (Jetson / GPU) Jetson Nano, Xavier NX
• DeepStream Version DS5.0GA
