Jetson Xavier NX
• DeepStream Version
6
4.6
• TensorRT Version
Smart Record Bug
We are using smart record to record video clips from RTSP streams. The smart record is configured for four discrete RTSP streams, the snippet from the config files is included below:
[source-0] (and for 1,2, and 3)
enable = 1
type = 4
uri = rtsp://
gpu-id = 0
cudadec-memtype = 0
camera-id = 0
rtsp-reconnect-interval-sec = 5
smart-record = 1
smart-rec-dir-path =
smart-rec-file-prefix = cam-0
smart-rec-video-cache = 11
smart-rec-container = 0
smart-rec-start-time = 7
smart-rec-default-duration = 8
smart-rec-duration = 4
The trigger to begin Smart Record is as follows:
guint startTime = appCtx->config.multi_source_config[camera_id].smart_rec_start_time;
guint duration = appCtx->config.multi_source_config[camera_id].smart_rec_duration;
NvDsSRStart(recorder_ctx, &sessId, startTime, duration, userData)
This call records correctly most of the time - videos are recorded of about 9-10 seconds long (4+7 seconds minus time to find an I-frame), some videos are recorded which are much longer. Longest recorded was 16 minutes 41 seconds.
Is there a reason why the Smart Record would not stop once the duration is reached ?
