When setting up smart record with NvDsSRCreate() you must specify the video cache size. How should users choose a value here. The example app just uses 30 seconds but if pre-record time is just 3 seconds for example then should the cache size be set to 3 seconds or maybe a little bit more to be safe, like 5 seconds.
Having a large cache size just takes up memory for no benefit from what I can tell ?
• Hardware Platform (Jetson / GPU) ANY • DeepStream Version DS5.0
Does change video cache size not solve the issue?
30s is the default value.
seems we are not in same page?
what do you mean pre-record? video cache start time?
If using the deeepstream test5 app you can see a sample of smart-record with the following parameters:
smart-record=1
smart-rec-video-cache=30
smart-rec-duration=10
smart-rec-start-time=3
smart-rec-interval=60
smart-rec-file-prefix=<file name prefix>
smart-rec-dir-path=<path of directory to save the file>
When I say “pre-record” it means that buffered video will be record x seconds before now, where x is specified by smart-rec-start-time.
If the smart-rec-start-time is 3 seconds. What is the point of having a cache size of 30 seconds. Is that just wasting memory? Should the cache size also be 3 seconds for best efficiency ?
the property can be changed, smart-rec-video-cache=**, you can change to a smaller value, but to make recording work, it should be greater equal 3 in your case. smart-rec-start-time is 3 seconds
•smart-rec-video-cache=
Size of video cache in seconds. This parameter will increase the overall memory usages of the application.
