Smartlead BF8S106A-100-02 Camera Interface on Nvidia Drive Orin
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I am trying to run the Smartlead BF8S106A-100-02 Camera on Drive Orin using the sample_camera example, but i am unable to get the camera stream, requesting for support
Dear @arpit.agarkar ,
Did you test nvspl_camera? If so, could you share the working command.
Also, what is the camera GMSL parameters used in Json file?
I am testing with ./sample_camera located inside /usr/local/driveworks/bin in drive orin
the rig file config is given below
“rig”: {
“sensors”: [
“name”: “camera:sample0”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [
0.0,
0.0,
0.0
“t”: [
1.8621,
-0.1939,
1.3165
“parameter”: “camera-name=ROSIM728S2RU2030NB1,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216”,
“properties”: {
“Model”: “ftheta”,
“bw-poly”: “0.000000000000000 5.35356812179089e-4 4.99266072928606e-10 4.27370422037554e-12 -6.68245573791717e-16”,
“cx”: “1927.764404”,
“cy”: “1096.686646”,
“height”: “2168”,
“width”: “3848”
“protocol”: “camera.gmsl”
“vehicle”: {
“valid”: false
“version”: 2
The camera is connected to Group A0
Is it a typo instead of R0SIM728S2RU2030NB1 ? Also, is the camera is FOV 30 or 70?
Is camera working with sipl_camera (IMX728 Using 2 Lane CPHY | NVIDIA Docs)
Its 70 can you please provide correct config for same
Tried the same with 70 also, didnt work
Can you try ./nvsipl_camera -c R0SIM728S2RU1070NB1_CPHY_x2 -m '0x0001 0x0000 0x0000 0x0000' -sR012 -r 3
./nvsipl_camera -c * R0SIM728S3RU1070NB2_CPHY_x2 -m '0x0001 0x0000 0x0000 0x0000' -sR012 -r 3 and share the logs
Could you please provide any update for this topic?
With R0SIM728S2RU2030NB1 I was able to configure the camera @SivaRamaKrishnaNV
