Hi!
I have my custom board and trying to run shmoo test which passes the SDRAM subnet test but now failing the test of walking ones.
Here is a log for the test that I run.
Do you have any suggestion?
Welcome to…
_ _ _ ___ ___ __
//\ ___ | |__ ()| | ___ //\ /\ / /
/ \ / _ \ | ’ \ | || | / _ \ / \ // /// /\ /\
/ //\ | () || |) || || || // //\ / _/// /_// _\
/ / _/ |.__/ |||| _|/ /_//_,’ _/
Copyright 2008 by NVIDIA Corporation. All rights reserved. All
information contained herein is proprietary and confidential to NVIDIA
Corporation. Any use, reproduction, or disclosure without the written
permission of NVIDIA Corporation is prohibited.
Intermediate results printed to the .out file###
Setting PLLM972##Rdv##c1290i1450h1100 State:
Rdv: 26
spawning nvhost: [‘C:\ShmooPackageV1.0.2_Public\nvhost.exe’, ‘-C’, ‘50001’, ‘–avp’, ‘tests\debug_nvt124_rvds_armv4\wfblit_lite.axf’, ‘–sdram’, ‘c:\users\faiz\appdata\local\temp\tmposwttgw’, ‘-t’, ‘30’, ‘–port’, ‘None’, ‘–chip’, ‘t124’, ‘–skip-reset’, ‘–’, ‘-fc’, ‘0,50,0’, ‘-vic’, ‘312’, ‘-reg’, ‘1’, ‘-log’, ‘0’, ‘-m’, ‘0xbf800000’, ‘-z’, ‘16’, ‘-s’, ‘0xffffffff’, ‘-n’, ‘972##Rdv##c1290i1450h1100’, ‘-b’, ‘i’, ‘–’]
nvhost: ========================================
nvhost: Found --chip parameter
Error ParseFieldName: (null)
Error processing statement: SDRAM[0].PllMSetupControl=0x00000000
Error processing statement: SDRAM[0].EmcBctSpare1=0x00000000
nvhost: …success! Found t124
nvblserver: Loading “tests\debug_nvt124_rvds_armv4\wfblit_lite.axg” via usb:…
Done.
WARNING: Ignoring auto-detect due to --chip parameter
clk_src_addr[clk][1]
(‘VIC’, ‘PllC3’, 0, 5)
(‘HOST1X’, ‘PllC2’, 0, 1)
base_value: 0x6000602c, src: PllP0, n:0x 1, m:0x0
base_value: 0x40106801, m: 0x 1, n:0x68, p:0x1
_board=PM375
rail=VDD_CORE
pmu_type=AMS
pmu_type_ifc=i2c4
pmu_ping_dev= 64
chip=t124
_board=PM375
rail=VDD_CORE
pmu_type=AMS
pmu_type_ifc=i2c4
pmu_ping_dev= 64
chip=t124
…Now connected to target using usb
Hit a Breakpoint. Use shrun to continue.
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(60006678) = 0x00000000
Enter command:
Enter command: nvhost: *(60006180) = 0x00000000
Enter command:
Enter command: nvhost: *(6000602C) = 0x00000000
Enter command:
Enter command: nvhost: *(60006028) = 0x20000040
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(60006008) = 0xefddf326
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(60006014) = 0x000004c0
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D01C) = 0x00000100
Enter command: nvhost: *(7000D01C) = 0x00000000
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D010) = 0x00000032
Enter command:
Enter command:
Enter command: nvhost: *(60006008) = 0xefdd7326
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(60006014) = 0x000084c0
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D01Crange_check is done
I2C write: dev(0x40), addr(0x1), data(0x45)
_board=PM375
rail=VDDIO_DDR
pmu_type=AMS
pmu_type_ifc=i2c4
pmu_ping_dev= 64
chip=t124
range_check is done
I2C write: dev(0x40), addr(0x2), data(0x42)
) = 0x00000100
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D010) = 0x00000045
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter co_board=PM375
rail=VDD_DDR_HS
pmu_type=AMS
pmu_type_ifc=i2c4
pmu_ping_dev= 64
chip=t124
range_check is done
I2C write: dev(0x40), addr(0x10), data(0xc)
_board=PM375
rail=VDD_RTC
pmu_type=AMS
pmu_type_ifc=i2c4
pmu_ping_dev= 64
chip=t124
range_check is done
I2C write: dev(0x40), addr(0x13), data(0x22)
Enter command: nvhost: *(7000D010) = 0x00000042
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D010) = 0x0000000c
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command:
Enter command: nvhost: *(7000D010) = 0x00000022
Enter command: target_stdout: enter NvTestMain V01
target_stdout: Processing argument 1: -fc
target_stdout: Processing argument 3: -vic
target_stdout: -vic 312
target_stdout: Processing argument 5: -reg
target_stdout: Processing argument 7: -log
target_stdout: Processing argument 9: -m
target_stdout: setting offset of the tested memory to 0xbf800000
target_stdout: Processing argument 11: -z
target_stdout: Processing argument 13: -s
target_stdout: Processing argument 15: -n
target_stdout: Processing argument 17: -b
target_stdout: The number of pattern: 16, box num 30
target_stdout: box width/height 2048 128 Surface width/height: 2048 3840
target_stdout: init sdram
target_stdout: Memory size = 0x00000400
target_stdout: SDRAM Subtest Start
target_stdout: SDRAM Subtest PASS
target_stdout: SDRAM test PASSED
target_stdout: Breaking after sdram init…
nvhost: OK
Enter command: target_stdout: Register Engine
target_stdout: Find Engine id: 0x5d
target_stdout: search id: 0x5e
target_stdout: search id: 0x5d
target_stdout: Engine ID: 0x5d found
target_stdout:
target_stdout:
target_stdout: -------Start: sanity in Register based mode
target_stdout: Board: E1186
target_stdout: top 0xfffffffe
target_stdout: initBLit
target_stdout: Init Vic Frequency Ctrl
target_stdout: Skipping pllc programming
target_stdout: SOURCE_VIC reg: 0xa0000000 VIC source: PLLC3_OUT0
target_stdout: ENB X reg: 0x01040000 vic clock: enable
target_stdout: ENB L reg: 0x90400130 host1x clock: enable
target_stdout: AllocSyncpt
target_stdout: channe base:0x50000000 sync base:0x2100, syncpt0 base:0xf80
target_stdout: prep surface
target_stdout: DRAM addr range: 0x80000000 - 0xfffffffe
target_stdout: DRAM footprint: 0xbf800000 - 0xc0700000 (wfblit)
target_stdout: DRAM used: 15.0MB (blit uses 15.0MB)
target_stdout: == Range 0 in 1: 0xbf800000 - 0xc06fffff
target_stdout: wfblitcore
target_stdout: Patterns loaded. starting blits.
target_stdout: PMC aperture space
target_stdout: PMC_PLLP_WB0_OVERRIDE reg: 0x00000422
target_stdout: PLLM_WB0_OVERRIDE_FREQ reg: 0x0000010c
target_stdout: PMC:PLLP: override: disable
target_stdout: PMC:PLLM: override: disable (12,1)
target_stdout:
target_stdout: CAR aperture space
target_stdout: PLLM: 972MHz(1,81,0), PLL_BASE: 0x4c005101,
target_stdout: PLLP: override: enable
target_stdout: PLLP: 432MHz(2,72,0), PLL_BASE: 0x58004802,
target_stdout: PLLC: 624MHz(1,104,1), PLL_BASE: 0x48106801,
target_stdout: EMC source clk: PLLM_UD, SOURCE_EMC: 0x80000000
target_stdout: (ref=12MHz)
target_stdout: EMC freq: 972MHz
target_stdout: start box. loops: 0x0 numbox: 30
target_stdout: end box
target_stdout: Programming done. Waiting test done.
target_stdout: ----------------------
target_stdout: T124 Memory Statistics
target_stdout: Stats (
target_stdout:
target_stdout: Channel 0:
target_stdout: DEV 0:
target_stdout: .RD (
target_stdout: .RD8 (
target_stdout: .WR (
target_stdout: .WR8 (
target_stdout: .ACT (
target_stdout: .REF (
target_stdout: .SREF (
target_stdout: .E1CA (
target_stdout: .E1SA (
target_stdout: .E0CA (
target_stdout: .E0SA (
target_stdout: .E1CN (
target_stdout: .E1SN (
target_stdout: .E0CN (
target_stdout: .E0SN (
target_stdout:
target_stdout: DEV 1:
target_stdout:
target_stdout: Channel 0 Bandwidth(avg): 2817MB/s, or 36% (assuming static 972MHz)
target_stdout: =====================
target_stdout: End Memory Statistics
target_stdout: Blit done. The blit took 0.0 seconds
target_stdout: Read back check. Mask = 0xffffffff
target_stdout:
target_stdout: index: 0x0 box/x/y: 0/8/0 Expected:0x100 Actual:0x80000
target_stdout: Physaddr: 0xbf800020
target_stdout: Default Pattern. Init Pattern format: LongMats, pattern index: 0x0.
target_stdout: Current Pattern format: WalkingOnes, pattern index: 0x1.
target_stdout: Physical Location. rank 0x1, channel(sp): 0x0
target_stdout:
target_stdout: index: 0x1 box/x/y: 0/9/0 Expected:0x200 Actual:0x100000
target_stdout: Physaddr: 0xbf800024
target_stdout:
target_stdout: index: 0x2 box/x/y: 0/10/0 Expected:0x400 Actual:0xfff7ffff
target_stdout: Physaddr: 0xbf800028
target_stdout:
target_stdout: index: 0x3 box/x/y: 0/11/0 Expected:0x800 Actual:0xffefffff
target_stdout: Physaddr: 0xbf80002c
target_stdout:
target_stdout: index: 0x4 box/x/y: 0/12/0 Expected:0x1000 Actual:0x100
target_stdout: Physaddr: 0xbf800030
target_stdout:
target_stdout: index: 0x5 box/x/y: 0/13/0 Expected:0x2000 Actual:0x200
target_stdout: Physaddr: 0xbf800034
target_stdout:
target_stdout: index: 0x6 box/x/y: 0/14/0 Expected:0x4000 Actual:0x400
target_stdout: Physaddr: 0xbf800038
target_stdout:
target_stdout: index: 0x7 box/x/y: 0/15/0 Expected:0x8000 Actual:0x800
target_stdout: Physaddr: 0xbf80003c
target_stdout:
target_stdout: index: 0x8 box/x/y: 0/16/0 Expected:0x10000 Actual:0xaaaaaaaa
target_stdout: Physaddr: 0xbf800040
target_stdout:
target_stdout: index: 0x9 box/x/y: 0/17/0 Expected:0x20000 Actual:0xaaaaaaaa
target_stdout: Physaddr: 0xbf800044
target_stdout: wfblitcore done!
target_stdout: WfBlitCoreRun() returned 524291.
target_stdout: [fail: SubtestWfblit at /share/git-dev/dev-t124-bringup/tests/diags/mods/tests/wfblit_lite/wfblit.c:670]
target_stdout: printing errors!
target_stdout: Miscs info:
target_stdout: DRAM WIDTH: X64
target_stdout: DRAM TYPE: DDR3
target_stdout: DRAM DATA SWZL: LOWER
target_stdout:
target_stdout: Error info:
target_stdout: Bit FlipsToOne FlipsToZero
target_stdout:
target_stdout: Channel: 0x1
target_stdout: 00000000 00335318 00332686
target_stdout: 00000001 00346101 00338702
target_stdout: 00000002 00346996 00334915
target_stdout: 00000003 00354265 00338322
target_stdout: 00000004 00331806 00343432
target_stdout: 00000005 00344107 00343447
target_stdout: 00000006 00339428 00339959
target_stdout: 00000007 00344423 00344730
target_stdout: 00000008 00345860 00336223
target_stdout: 00000009 00336920 00334241
target_stdout: 00000010 00324198 00323844
target_stdout: 00000011 00331031 00321934
target_stdout: 00000012 00329002 00333617
target_stdout: 00000013 00335812 00333101
target_stdout: 00000014 00322625 00319134
target_stdout: 00000015 00327498 00322021
target_stdout: 00000016 00340911 00331733
target_stdout: 00000017 00332717 00346228
target_stdout: 00000018 00340191 00331389
target_stdout: 00000019 00347854 00338082
target_stdout: 00000020 00337853 00345263
target_stdout: 00000021 00333544 00338768
target_stdout: 00000022 00344888 00334324
target_stdout: 00000023 00330432 00347565
target_stdout: 00000024 00352876 00324827
target_stdout: 00000025 00352195 00325852
target_stdout: 00000026 00330388 00319914
target_stdout: 00000027 00330238 00320586
target_stdout: 00000028 00336573 00333057
target_stdout: 00000029 00339347 00333017
target_stdout: 00000030 00337219 00317298
target_stdout: 00000031 00328516 00322455
target_stdout:
target_stdout: Found 1174889 memory errors. Channel 0: 0, Channel 1: 1174889
target_stdout: … Stopping showing detail info after 10 errors
target_stdout: Use -ec to control count of error output
target_stdout: AP: Fail: Byte3 = 0x00000001 Byte2 = 0x00000001 Byte1 = 0x00000001 Byte0 = 0x00000001
target_stdout: ------- End: sanity in Register based mode
target_stdout: [fail: SubtestWfblit]
target_stdout: total subtests: 1
target_stdout: total failures: 1
target_stdout:
nvhost: OK
Enter command: target_exit(1)
nvhost: QUIT
error: the test application failed
Result: 0x1
Estimated End Time: Thu Nov 08 10:20:48 2018
===SHMOO COMPLETE===
