I want to render scene with smooth triangles, not flat triangles.
So i am providing the geometry with primitive triangles with 3 vertices and 3 vertices normals.
But no matter what I am doing, I will always get flat triangles.
I am using the intersection and bounding box program provided by triangle_mesh.cu, basically everything provided by the sample6. The vertices and normal buffers + vertices/normal indices buffers are set correctly and the phong shade is the default shader in this program i guess.
So how can I get a smooth triangulation ? Do I have to change the intersection/ bounding box program?
