I received two NVIDIA SN2100 switches. I tried to install Sonic from the Github page.
The installation went well, but after I noticed the vent runs at 100% and the status led turned red. Is there any known fix for this problem?
jsl2
April 26, 2023, 4:15am
2
It is not clear what version you’ve installed, but there is one known issue regarding with fans. Please see more details below:
sonic-net:master
← Junchao-Mellanox:fix-thermal-master
opened 07:34AM - 07 Dec 21 UTC
Please make sure you've read and understood our contributing guidelin… es:
https://github.com/Azure/SONiC/blob/gh-pages/CONTRIBUTING.md
** Make sure all your commits include a signature generated with `git commit -s` **
If this is a bug fix, make sure your description includes "fixes #xxxx", or
"closes #xxxx" or "resolves #xxxx"
Please provide the following information:
#### Why I did it
Optimize thermal control policies to simplify the logic and add more protection code in policies to make sure it works even if kernel algorithm does not work.
#### How I did it
1. Reduce unused thermal policies
2. Add timely ASIC temperature check in thermal policy to make sure ASIC temperature and fan speed is coordinated
3. Minimum allowed fan speed now is calculated by max of the expected fan speed among all policies
4. Move some logic from fan.py to thermal.py to make it more readable
#### How to verify it
1. Manual test
2. Regression
#### Which release branch to backport (provide reason below if selected)
- Note we only backport fixes to a release branch, *not* features!
- Please also provide a reason for the backporting below.
- e.g.
- [x] 202006
- [ ] 201811
- [ ] 201911
- [ ] 202006
- [ ] 202012
- [ ] 202106
#### Description for the changelog
Write a short (one line) summary that describes the changes in this
pull request for inclusion in the changelog:
#### A picture of a cute animal (not mandatory but encouraged)
If you already have versions mentioned in there, then please open a case with tech dump for further troubleshooting.
Thanks, I installed cumulus as a solution, it is working as expected.
system
Closed
May 18, 2023, 4:22pm
4
