I would recommend to check few things
- Latest Mellanox OFED v5.3 used on the tcpdump host
- Latest version of tcpdump and libpcap is in use on tcpdump host
- Close NUMA used to run tcpdump
On my setup, tcpdump doesn’t lose the packets and I’m running tcpdump on the same host as the ib_write_bw client. Speed is about 90 Gbps
[root@XXXX ~]# mlnx_perf -i ens1f0 | egrep [r]x_bytes
rx_bytes_phy: 11,361,121,028 Bps = 90,888.96 Mbps
rx_bytes_phy: 11,359,701,018 Bps = 90,877.60 Mbps
rx_bytes_phy: 10,054,267,618 Bps = 80,434.14 Mbps
rx_bytes_phy: 10,486,318,032 Bps = 83,890.54 Mbps
rx_bytes_phy: 11,351,984,490 Bps = 90,815.87 Mbps
rx_bytes_phy: 11,354,548,936 Bps = 90,836.39 Mbps
rx_bytes_phy: 11,352,971,872 Bps = 90,823.77 Mbps
[root@XXXX ~]# tcpdump -i mlx5_0 -etn -c 1000000 -s 65535 | head -n 5
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on mlx5_0, link-type EN10MB (Ethernet), capture size 65535 bytes
24:8a:07:9c:01:86 > 02:48:a0:79:c0:1a, ethertype IPv4 (0x0800), length 1082: 192.168.150.3.58171 > 192.168.150.4.roce: UDP, length 1040
tcpdump: Unable to write output: Broken pipe
[root@XXXX ~]# tcpdump -i mlx5_0 -etn -c 1000000 -s 65535 | tail -n 5
1000000 packets captured
1000000 packets received by filter
0 packets dropped by kernel
