Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: Geforce RTX 5080
- Driver Version:
Topic Description
Detailed Description
Title: SO-ARM101 EE Frame Alignment Issue (Fixed Jaw Causes Collision) – Best Strategy in Isaac Sim with Lula IK?
Hi everyone,
I’m working with the SO-ARM101 manipulator in Isaac Sim and running into an issue related to the end-effector (EE) frame definition and how it affects grasp execution.
Problem Description:
The EE frame appears to be defined at the tip of the fixed jaw rather than at the center of the gripper (i.e., between the jaws). Because of this:
When I solve IK using Lula IK, the solver tries to bring the fixed jaw tip to the target pose.
During grasping, this causes the fixed jaw to align with the center of the object, instead of the gripper center.
As a result, the fixed jaw collides with the object before a proper grasp can occur.
Current Setup:
Simulator: Isaac Sim
IK Solver: Lula IK
Task: Pick-and-place / grasping
Input: Target pose (object pose or grasp pose)
EE frame: Default frame attached to fixed jaw tip
Observed Behavior:
IK converges successfully to the given target.
However, execution leads to collision because the EE reference is not aligned with the intended grasp center.
Questions / Guidance Needed:
Best Practice for EE Frame Definition:
Should the EE frame be redefined to the center between the jaws instead of the fixed jaw tip?
If yes, what is the recommended way to modify this in Isaac Sim (USD edit vs. runtime transform)?
Offset Strategy:
Is it better to:
Apply a pre-grasp offset to the target pose before feeding it to Lula IK, OR
Redefine the EE frame entirely so that IK naturally aligns with the grasp center?
Grasping Pipeline Consideration:
For robust grasping (especially future cases with random objects), what is the preferred approach:
IK to a grasp pose defined in gripper-center frame, OR
IK to a proxy frame + motion refinement?
Lula IK Constraints:
Does Lula IK assume the EE frame is the true tool center point (TCP)?
Any recommended way to handle TCP offsets cleanly within Lula?
What I’m Trying to Achieve:
A stable grasping pipeline where:
The gripper approaches the object without collision
The grasp is centered properly
The solution generalizes to arbitrary object shapes (future goal: random objects / perception-driven grasping)
If anyone has dealt with similar EE frame misalignment or has a recommended architecture for grasping in Isaac Sim (especially with Lula IK), I’d really appreciate your guidance.
Thanks in advance!
