Description
I recently learn how to use tensorrt, and I convert a hrnet from onnx to trt successfully. But when i try to use the trt model in python 3.8, it cost too much time in “with open(“path/to/trt/file”, “rb”) as f, trt.Runtime(logger) as runtime:”. There is no warning or error message. And the cpu is actually working on it, without any output. I don’t know whether the model size is the reason, cause my trt file is about 500MB. And when i run the python file, I open gpustat or nvidia-smi is also very very very slowly.
Could you explain why it occured? How could i fix it up?
Environment
TensorRT Version= 8.2.1.8:
GPU Type=Titan RTX:
Nvidia Driver Version = 440
CUDA Version=10.2
CUDNN Version=8.3.1
Operating System + Version=ubuntu1804
Python Version (if applicable)=3.8
PyTorch Version (if applicable)=1.9:
import tensorrt as trt
logger = trt.Logger(trt.Logger.INFO)
with open(".myhrnetw48out.trt", "rb") as f, trt.Runtime(logger) as runtime:
engine=runtime.deserialize_cuda_engine(f.read())
model_all_names= []
for idx in range(engine.num_bindings):
is_input = engine.binding_is_input(idx)
name = engine.get_binding_name(idx)
op_type = engine.get_binding_dtype(idx)
model_all_names.append(name)
shape = engine.get_binding_shape(idx)
print('input id:',idx,' is input: ', is_input,' binding name:', name, ' shape:', shape, 'type: ', op_type)
