socket error while trying to set up jupyter notebook environment.
currenty inside the container bash, this problem comes up while following the transfer learning documentation. Some help is appreciated.
root@15039968ebec:/workspace# jupyter notebook --ip 192.168.65.15 --port 8888 --allow-root
File “/usr/local/bin/jupyter-notebook”, line 10, in
sys.exit(main())
File “/usr/local/lib/python2.7/dist-packages/jupyter_core/application.py”, line 267, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py”, line 657, in launch_instance
app.initialize(argv)
File “</usr/local/lib/python2.7/dist-packages/decorator.pyc:decorator-gen-7>”, line 2, in initialize
File “/usr/local/lib/python2.7/dist-packages/traitlets/config/application.py”, line 87, in catch_config_error
return method(app, *args, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/notebook/notebookapp.py”, line 1630, in initialize
self.init_webapp()
File “/usr/local/lib/python2.7/dist-packages/notebook/notebookapp.py”, line 1407, in init_webapp
self.http_server.listen(port, self.ip)
File “/usr/local/lib/python2.7/dist-packages/tornado/tcpserver.py”, line 143, in listen
sockets = bind_sockets(port, address=address)
File “/usr/local/lib/python2.7/dist-packages/tornado/netutil.py”, line 168, in bind_sockets
sock.bind(sockaddr)
File “/usr/lib/python2.7/socket.py”, line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 99] Cannot assign requested address
I mistakenly thought of using the general transfer learning toolkit by Nvidia for clara model training. However the correct way is probably just pulling the clara_train docker and download models from ngc, this will give you access to MMAR where someone can find out about all the config files and scripts. Thanks :)
