system
1
Hi All
I am trying to setup the soft roce on my Ubuntu 14.04 following the steps mentioned here in
HowTo Configure Soft-RoCE https://community.mellanox.com/s/article/howto-configure-soft-roce
But Its failing at step 7, as those rpms can be installed only on Fedora version not Ubuntu 14.04
How can install those libraries on Ubuntu 14.04.?
Can someone help me in regard to this? Do I have to change the setup to Fedora and try all over again?
any suggestions are appreciated?
regards
Sandeep
rage
2
Hello Sandeep,
Please use the link below to repository for missing packages for Step 7.
GitHub - SoftRoCE/librxe-dev: Development repository for RXE user space code. GitHub - SoftRoCE/librxe-dev: Development repository for RXE user space code.
Cheers,
.R
HI:
I am also trying to setup the soft roce on my Ubuntu 16.04/18.04 following the steps mentioned here in
HowTo Configure Soft-RoCE https://community.mellanox.com/s/article/howto-configure-soft-roce.
But it failed when I use sudo make install
to install rdma-core. it prompt as follow:
CMake Error at cmake_install.cmake:73 (file):
file INSTALL cannot find “/home/liao/Downloads/rdma-core/build/lib/librdmacm.so.1.2.27.0”.
regards
Liaoweizhi
