Software PWM on Orin Nano any GPIO pin
Hi there,
I was discussing with AI the possibilities of generating a software PWM signal (as opposed to hardware PWM) on pin 19, 21 and 23 for instance.
My point is to drive LEDs with PWM, so I was wondering if there was an easy way to do this, please.
Thank you!
Tom
Hello @tom.hall1 ,
Here is a guide for the Jetson GPIO Library: How to test GPIO with Jetson GPIO Library
You can take this example as a starting point for your implementation.
Feel free to contact us for more details.
Felipe Solano
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Hello @felipe.solano
Thank you for this, but I was hoping for a way to put software PWM on any gpio of the Jetson Nano or Orin.
Do you know how I could do that please?
Thank you !
Hello @tom.hall1 ,
Here is a general scaffold for a implementation on the pins you are mentioning. It is mostly the same example of the shared Wiki and I added a couple of loops:
import Jetson.GPIO as GPIO
import time
# Test pins on Orin Nano
output_pins = [19, 21, 23]
# Software PWM settings
frequency = 10      # Hz
duty_cycle = 50     # percent
duration = 10       # seconds
def main():
    GPIO.setmode(GPIO.BOARD)
    for output_pin in output_pins:
        GPIO.setup(output_pin, GPIO.OUT, initial=GPIO.LOW)
    period = 1.0 / frequency
    high_time = period * (duty_cycle / 100.0)
    low_time = period - high_time
    start_time = time.time()
    try:
        while time.time() - start_time < duration:
            print("--> GPIOs set to High")
                GPIO.output(output_pin, GPIO.HIGH)
            time.sleep(high_time)
            print("--> GPIOs set to Low")
                GPIO.output(output_pin, GPIO.LOW)
            time.sleep(low_time)
    except KeyboardInterrupt:
        print("--> Stopped by user")
    GPIO.cleanup()
if __name__ == '__main__':
    main()
Felipe Solano
In the end, I’ll be using C code and a websocket to drive a software PWM.
This is much smoother and predictible, although the implementation needs some debugging.
Thank you for your help,
Tom
