Solder Bridge vs 0-ohm resistor for Auto-Start
Hi all, my aim is to get the TX2 to auto-start. Soldering a 0-ohm resistor on J27 works fine, but I was wondering if it’s okay just add a solder bridge to those pins for the auto-start feature. Is 0-ohm resistor just an elegant solution or has something more to it? Will be helpful to know the pro’s and con’s for both the methods if any. Thanks.
Hi, it is same here to use 0 ohm resistor or solder bridge.
