Solicitud de soporte técnico – NVIDIA Triton Inference Server en Blackwell MIG
Hello NVIDIA Support Team,
We are currently deploying (Triton + DeepStream) on a Dell/Nvidia server. However, we are experiencing an issue with NVIDIA Triton Inference Server, which fails to reach the Ready state.
1. Triton Inference Server Issue
During startup, Triton’s memory manager attempts to use the CUDA Virtual Memory Management API, specifically cuMemGetAllocationGranularity. However, the operation fails, causing the process to terminate with the following error:
failed to call cuMemGetAllocationGranularity: operation not supported
exit 139 - CrashLoopBackOff
2. GPU and MIG Behavior
We identified that the server is not detecting the full Blackwell GPU, but only a single MIG instance with the 1g.24gb profile.
The environment uses the DC-1-24Q profile with MIG Locked configuration.
While reviewing NVIDIA documentation, we found references to Triton deployments with MIG, mainly on A100 and A30 architectures. However, we could not find a documented solution for this specific scenario on Blackwell.
3. Support Request
We would appreciate your assistance in investigating this issue, specifically to:
  • Validate Triton Inference Server compatibility with Blackwell under this MIG configuration.
  • Identify why the cuMemGetAllocationGranularity API returns operation not supported.
  • Review the CUDA, MIG, and Triton configurations required to resolve this issue.
  • Determine whether a configuration change or workaround would allow us to run Triton within our current architecture.
We would appreciate your support in identifying a solution that allows us to fully leverage Triton’s capabilities within our architecture.
We look forward to your feedback.
Best regards,
Juan
Thanks for the detailed report. Based on your logs, this doesn’t appear to be a DeepStream issue. Please open an issue in the Triton GitHub repo: Issues · triton-inference-server/server · GitHub — the Triton team there will give you a better answer.
