hola buenas, como hago para poder usar el solid works en NVIDIA Omniverse Launcher??
You mean how do you import solidworks files? You can just import your STP or IGES files directly into USD Composer. Or you can try to convert your files into USD format first. You may need to make sure that you have the “CAD Converter” extension loaded in USD Composer to get all of the files types you need.
