[Solution] The NameError: name 'PhysicsContext' in the Isaac Sim tutorial '5. Script Editor'
Hi, here is the solution!
While I follow the, great and awesome, Isaac Sim tutorial ‘5. Script Editor’ below, an error happens.
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_gui_script_editor.html#script-editor
Problem
When the code of ‘5.4. Isaac Sim Core APIs’ below is run,
import numpy as np
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.core.objects.ground_plane import GroundPlane
PhysicsContext()
GroundPlane(prim_path="/World/groundPlane", size=1000, color=np.array([0.5, 0.5, 0.5]))
DynamicCuboid(prim_path="/World/cube",
position=np.array([50, 20, 100.0]),
size=np.array([50, 50, 50]),
color=np.array([20,30,0]))
The error below happens:
NameError: name ‘PhysicsContext’ is not defined
At:
executing: Python 0…(5):
Environment
Ubuntu AMI Container install on AWS EC2
Solution
At the top of the code, insert the below:
from omni.isaac.core import PhysicsContext
Thank you for presenting the solution.
