[SOLVED] CUDA Error: cuModuleLoad
Hi Rama,
I compiled the samples and the library on Ubuntu 16.04 LTS.
Linux (64bit)
Quadro K4000, Runtime Ver: 3.0
The library and the sample compile without any issues as such. But when I run any of the samples, I get this error
CUDA Error: file not found (func: cuModuleLoad, caller: Allocator)
Thanks,
Vimal
Hi Vimal,
Be sure that you run ‘make install’ after running make on each sample. This error indicates that one of the .ptx modules created by GVDB library was not found. These are copied to the executable location with make install, which should be run on the library, and on the samples after make.
Regards,
Rama
Hi Rama,
Thanks for the reply. That fixed it.
Regards,
Vimal
