I am getting started with CUDA. I have slackware 14.1 64-bit running on a Dell Precision m4400 machine.
I have installed CUDA toolkit 6.0
I have the NVIDIA driver installed : lspci | grep -i nvidia shows
“01:00.0 VGA compatible controller: NVIDIA Corporation G96GLM [Quadro FX 770M] (rev a1)”
This is the 331.20 driver, I am assuming that CUDA 6 works with this driver version.
I am trying to compile and run the example matrixMul from CUDA-Samples/0_Simple. It compiles correctly, but when I run it using ./matrixMul -device=0 -wA=10 -hA=10 -wB=10 -hB=10, I get an error
“cudaGetDevice returned error code 3, line(396)”
Does anyone have an idea on what is going wrong? Any help is most appreciated.
Update:
deviceQuery fails with the following error
"./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 3
→ initialization error
Result = FAIL"
