Hello.
I received my DGX Spark in mid-December, but with work and the holidays, I didn’t have time to use it until now. I just opened the box, ran the initial setup wizard, installed ComfyUI, and that’s about it.
Now, I want to run serious workloads on this machine and compile llama.cpp, but here’s the issue: when I check my “nvcc,” I see that I have CUDA version 12 installed (Build cuda_12.0.r12.0/compiler.32267302_0), whereas, if I understand correctly, I should have the version for CUDA 13.
Looking at what’s installed on my system with apt list --installed | grep -E 'toolkit', it seems I have two versions of the toolkit:
cuda-toolkit-13-0-config-common/inconnu,now 13.0.96-1 all [installé, automatique]
cuda-toolkit-13-0/inconnu,now 13.0.2-1 arm64 [installé]
cuda-toolkit-13-config-common/inconnu,now 13.1.80-1 all [installé, automatique]
cuda-toolkit-config-common/inconnu,now 13.1.80-1 all [installé, automatique]
nvidia-container-toolkit-base/inconnu,now 1.18.1-1 arm64 [installé, automatique]
nvidia-container-toolkit/inconnu,now 1.18.1-1 arm64 [installé, automatique]
nvidia-cuda-toolkit-doc/noble,now 12.0.1-4build4 all [installé, automatique]
nvidia-cuda-toolkit/noble,now 12.0.140~12.0.1-4build4 arm64 [installé]
I really don’t know how I ended up in this situation. I barely touched the system, just did a few updates. Looking at my history, I ran an apt full-upgrade; maybe that’s the culprit, but I’m not sure.
Any advice on how to clean up this mess and keep only the CUDA 13 version (which is supposed to be the default on this system, right)? I can “reset” the spark by reinstalling everything if necessary, but since this issue might recur, I would prefer a permanent solution.
Thanks for your help.
