Anyone get them to work. Don’t post stuff on here that will get you banned. I can’t even get mine to read udf file system. Sata connected slim blu ray writer.
You need both ISO9660 filesystem and UDF added to kernel. Probably you want Joliet as well. Without those in kernel compile it’ll never work. Incidentally, ISO9660 can be compiled as a module, but I think Joliet might be iffy. Not sure if UDF is ok as just a module.
Should be a module, I think. Exfat works in that fuse mod.
Grinch has the file systems built in.
