[SOLVED] "Error: Return value 2" during jetpack flash
I know that there are many posts about failed installations of jetpack but, from what I could found, there was no one else with the same issue as I did.
I am trying to flash jetpack from a ubuntu 64 bit host, both the host and the targe are connected to the internet and both have their IP provided by a DHCP server.
I was checking the following video as a guidance:https://www.youtube.com/watch?v=TB-bIayjBbc&index=29&list=WL
and everything went fine, until the point that I had to place the board in force recovery mode. I followed the instructions provided by the installer, confirmed with the video and also with the quick start guide but the installation stalled. On the log file I get the following lines:
[ 0.0499 ] Boot Rom communication
[ 0.0506 ] tegrarcm --rcm rcm_list_signed.xml
[ 0.0511 ] BR_CID: 0x34001001741141031800000008020440
[ 0.0515 ] Boot Rom communication failed
[ 0.0515 ]
Command tegrarcm --rcm rcm_list_signed.xml
Failed flashing t210ref."
Any guidance will be very appreciated.
Thanks in advance.
Cruz
Hello once again,
I forgot to select jetson TK1 on the installer GUI (the default was jetson TX1).
Sorry about the hassle.
Cruz
