I’m trying to save some variables in constant memory but I get some errors when nvcc links the program.
I have a C++ class that invokes some kernels. My *h and *cpp files are like:
myClass.h:
#include "kernels.h"
class myClass
private:
//some fields and private functions
public:
void invokeKernel(...);
myClass.cpp:
#include "myClass.h"
void myClass:myClass invokeKernel(...)
for (i = 0; i < N; i++) {
launchKernel<<<gridSize, blockSize>>>(v);
The kernel is inside *h file:
kernels.h:
__global__ void launchKernel(double value)
//do something
I want to save the variable “value” in constant memory, I have tried to add the constant qualifier in the file ‘kernels.h’ and copy the value before launch the kernel:
kernels.h:
__constant__ double value;
__global__ void launchKernel()
//do something
myClass.cpp:
cudaMemcpyToSymbol(&value, &v, sizeof(double), 0, cudaMemcpyHostToDevice);
launchKernel<<<gridSize, blockSize>>>();
When I try to compile and linkk the program I get the follow error:
nvlink error : Multiple definition of 'value' in 'build/Release_64b_CUDA/GNU+CUDA-Linux/otherClass1.o', first defined in 'build/Release_64b_CUDA/GNU+CUDA-Linux/otherClass2.o'
I don’t understand correctly the message because the variable ‘value’ only is defined in file ‘kernel.h’. Do I need define it in other file?
Thank you.
