Im trying to install the pycuda on Jetson TK1. When I tried to “sudo make install” :
arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.8/README.Bugs> for instructions.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 4
make: *** [install] Error 1
Another possible cause could be running out of memory (should make some traces in dmesg). If you used parallel make -j4, try with single make. If not enough, you may add swap.
