I have just received a Jetson TK1 (I am a newbie on teh nvidia forum!) and I have problem installing the Jetpack software.
I use a x86 PC, with boot from USB 3.0 key on which the linux ubuntu system is installed
jetson@jetpack:~/Téléchargements$ uname -a
Linux jetpack 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Note : system packages are all up-to-date (I performed apt-get update and upgrade before trying to install the JetPack software)
file sytem info (Partition type is ext4) :
jetson@jetpack:~/Téléchargements$ mount
/dev/sdb2 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
none on /sys/fs/pstore type pstore (rw)
/dev/sdb4 on /dos type vfat (rw,utf8,umask=007,gid=46)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=jetson)
jetson@jetpack:~/Téléchargements$ ^
I have downloaded the Jetpack from nvidia embeded website :
jetson@jetpack:~/Téléchargements$ ll
total 25152
drwxr-xr-x 3 jetson jetson 4096 nov. 22 18:13 ./
drwxr-xr-x 17 jetson jetson 4096 nov. 22 16:21 ../
drwxrwxr-x 4 jetson jetson 4096 nov. 22 18:14 _installer/
-rwxrwxr-x 1 jetson jetson 25742606 nov. 22 18:13 JetPack-L4T-2.0-linux-x64.run*
when executing the installer
jetson@jetpack:~/Téléchargements$ sudo ./JetPack-L4T-2.0-linux-x64.run
The GUI installer popup appears but, contrary to what is described in the quick start guide (http://ecee.colorado.edu/~ecen5653/ecen5653/doc/JETSON/Jeston_TK1_QuickStartGuide.pdf) :
- I don’t get any step3/page 8 - Licence agreement to validate
- it goes directly to step 4. Text message “Please specify…” is displayed but not the 2nd line “Installation directory” with associated text input. I click next… and then …
- I don’t see the step 5 / Installation type. I just see a screen “Installing”, with message “Please wait while Jetpack L4T is installed” with extracting ressources progression bar. After a few second a terminal popup with message “Please grant sudo permission to JetPack to continue installation. Sudo access only used when needed” appears and close almost immediately without any intervention from my part
- Around 25% progression from the installer a error popup message appear “Error occurs during installation.
Return Code: 1
2015/11/22 18:42:56 dialing:dial tcp 127.0.0.1:33335: connection refused” - when I click on ok/error popup, the jetpack installer close itself
Note :
- wifi is connected (I use this linux computer to post in nvidia forum)
- I have tried installation with both Jetson connected and not connected to the host linux pc through its usb cable (Jetson board looks to boot ok on its side)
Installer create a directory which contains this :
jetson@jetpack:~/Téléchargements$ ls -l _installer/
total 89216
-rwxr-xr-x 1 jetson jetson 20857632 nov. 13 10:53 Chooser
-rwxr-xr-x 1 jetson jetson 7100944 nov. 13 10:53 configure_host
-rwxr-xr-x 1 jetson jetson 957 nov. 13 10:53 cuda-l4t.sh
-rwxr-xr-x 1 jetson jetson 7048680 nov. 13 10:53 flash_os
drwxrwxr-x 2 jetson jetson 4096 nov. 13 10:53 icons
drwxr-xr-x 3 root root 4096 nov. 22 18:14 _installer
-rwxr-xr-x 1 jetson jetson 8118616 nov. 13 10:53 InstallUtil
-rwxr-xr-x 1 jetson jetson 7075680 nov. 13 10:53 JetPack_Uninstaller
-rwxr-xr-x 1 jetson jetson 20553920 nov. 13 10:53 Launcher
-rw-rw-r-- 1 jetson jetson 30 nov. 13 10:53 local.cfg
-rwxr-xr-x 1 jetson jetson 6871192 nov. 13 10:53 nv_info_broker
-r-xr-xr-x 1 jetson jetson 204 nov. 13 10:53 ocv.sh
-rwxr-xr-x 1 jetson jetson 7660360 nov. 13 10:53 PageAction
-rwxr-xr-x 1 jetson jetson 489 nov. 13 10:53 rc.local
-r--r--r-- 1 jetson jetson 440 nov. 13 10:53 remove_unsupported_cuda_samples.sh
-rwxr-xr-x 1 jetson jetson 419 nov. 13 10:53 report_ip_to_host.sh
-rwxr-xr-x 1 jetson jetson 3028881 nov. 13 10:53 run_command
-r-xr-xr-x 1 jetson jetson 114 nov. 13 10:53 run_gameworks_sample.sh
-rwxr-xr-x 1 jetson jetson 2979526 nov. 13 10:53 sudo_daemon
Any idea of what could be the issue’s cause and what could I try to fix it ?
Thanks !
