you may need to remove what you have installed so far before installing anything
reference steps can be found here: [url]Installation Guide Linux :: CUDA Toolkit Documentation
more reference: [url]https://devtalk.nvidia.com/default/topic/1000340/cuda-setup-and-installation/-quot-nvidia-smi-has-failed-because-it-couldn-t-communicate-with-the-nvidia-driver-quot-ubuntu-16-04/post/5110945/#5110945[/url]
i have just installed the rpm package nvidia-diag-driver-local-repo-rhel7-390.30-1.0-1.x86_64.rpm and yet to execute the following commands yum clean all; yum install cuda-drivers; reboot.
well yum install cuda-drivers gives me an error about dkms. It says package xorg-x11-drv-nvidia-libs-390.30-1.el7.x86_64 requires libvdpau(x86-64 >=0.5
→ Finished Dependency Resolution
Error: Package: 1:nvidia-kmod-390.30-2.el7.x86_64 (nvidia-diag-driver-local-390.30)
Requires: dkms
Error: Package: 1:xorg-x11-drv-nvidia-libs-390.30-1.el7.x86_64 (nvidia-diag-driver-local-390.30)
Requires: libvdpau(x86-64) >= 0.5
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
does someone knows a fix for this?
dkms error explained at the link I provided previously
EDITED
download the package somehow RPM CentOS 7 dkms 2.2.0.3 noarch rpm
sudo rpm -vih dkms-2.2.0.3-31.1.noarch.rpm
Does that resolve the issue?
unable to access the download rpm link. can you provide me a downloaded rpm for this or is there any other way to resolve this?
i’m not allowed to do wget in my environment (restricted)
is there no authentic way to fix this issue? I mean is there no nvidia source where i can get this particular package.
NVIDIA doesn’t provide dkms
I think you may download the package from RPM CentOS 7 dkms 2.2.0.3 noarch rpm
You may also approach DKMS on CentOS 7 · shawfdong/hyades Wiki · GitHub
Then execute
Thanks Andrey1984 and nvidia.
Got it fixed and the driver is successfully installed and running :)
dkms and libvdpau x86_64 were required to fix it.
got,
- dkms from [http://mirror.de.leaseweb.net/epel/7/x86_64/Packages/d/dkms-2.4.0-1.20170926git959bd74.el7.noarch.rpm]
- libvdpau from [RPM resource libvdpau(x86-64)]
**Note: libvdpau package available in the EPEL repo doesn’t work! [http://mirror.de.leaseweb.net/epel/7/x86_64/Packages/l/libvdpau-va-gl-0.4.2-6.el7.x86_64.rpm]
