Context
While productionizing a RAG chatbot at SecuAI (Postgres + pgvector), our embedding vectors would not index with ANN.
Environment
Vector DB: PostgreSQL 16 + pgvector (HNSW / cosine)
API: NVIDIA NIM (OpenAI-compatible endpoint)
Models tried:
nvidia/llama-3.2-nemoretriever-300m-embed-v2(2048D, fixed) -
sentence-transformers/all-MiniLM-L6-v2(384D) -
Final:
nvidia/llama-3.2-nv-embedqa-1b-v2at 1536D (configurable)
Symptom
ERROR: column cannot have more than 2000 dimensions for ivfflat index
(also blocks HNSW with classic vector type when > 2000D)
Root cause
pgvector ANN indexes require ≤ 2000 dimensions for vector. The 300M retriever emits 2048D and (today) doesn’t support dynamic dimensions.
Fix
Switch to nvidia/llama-3.2-nv-embedqa-1b-v2 and request 1536D at inference.
Embed calls (OpenAI-compatible)
from openai import OpenAI
import os
client = OpenAI(
api_key=os.environ["NVIDIA_API_KEY"],
base_url="https://integrate.api.nvidia.com/v1"
# Index time (documents/chunks)
idx = client.embeddings.create(
model="nvidia/llama-3.2-nv-embedqa-1b-v2",
input=["<doc chunk 1>", "<doc chunk 2>"],
encoding_format="float",
extra_body={"input_type": "passage", "truncate": "NONE", "dimensions": 1536}
# Query time
qry = client.embeddings.create(
input=["What is SoD risk F005 in SAP?"],
extra_body={"input_type": "query", "truncate": "NONE", "dimensions": 1536}
assert all(len(d.embedding) == 1536 for d in idx.data)
assert len(qry.data[0].embedding) == 1536
pgvector DDL
CREATE EXTENSION IF NOT EXISTS vector;
CREATE TABLE docs (
id bigserial PRIMARY KEY,
source text,
chunk_id int,
text text NOT NULL,
embedding vector(1536) NOT NULL,
model_ver text NOT NULL DEFAULT 'nv-embedqa-1b-v2/1536',
created_at timestamptz DEFAULT now()
CREATE INDEX docs_embedding_hnsw
ON docs USING hnsw (embedding vector_cosine_ops);
Retrieval
-- $1: 1536-D query vector
SELECT id, source, chunk_id, text,
1 - (embedding <#> $1) AS cosine_sim
FROM docs
ORDER BY embedding <#> $1
LIMIT 40; -- then rerank to top 6–8
Results
ANN indexing works (no 2000D error)
Lower latency vs flat scan
Better relevance using
input_type="passage"at index time,input_type="query"at query time -
Optional reranker (e.g.,
llama-3.2-nv-rerankqa-1b-v2) improved precision without noticeable latency
