Hi, i am new Nvidia Modulus, im trying to solve transient linear elasticity problem. the problem definition is a simple plate fixed at two ends with pressure applied at the upper surface. i have attached a png showing the problem definition.
However, i am not getting the expected results.
I have attached a short video comparing the result(deformation in normal direction) from PINN and ANSYS, as time progresses.
I’ve also attached my case file.
sample_transient.zip (4.8 KB)
Any help will be appreciated.
