Some error about USB camera And OV5693 on TX2
Hello there,I had some problems when I tried to open a camera on TX2. I can’t find my USB camera in /dev list. When I pluged in/out the USB camera there is nothing changed. But I can see the USB device in the lsusb.
Bus 002 Device 003: ID 2ba2:4d55
Bus 002 Device 002: ID 2109:0817 VIA Labs, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 17ef:6019 Lenovo
Bus 001 Device 003: ID 17ef:608c Lenovo
Bus 001 Device 002: ID 2109:2817 VIA Labs, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ID 2ba2:4d55 is my cam.I tried others USB camera and none of them can be recognized. All the USB camera producer claimed their product obey the UVC protocol. And I tried to use the camera with lib that producer offered, the camera works fine.I have no idea how to deal with it.
Another problem is I can’t open OV5693 by its vid . It’s OK when I use cv2.VideoCapture("nvarguscamerasrc … to open it. But when I made it cv2.VideoCapture(0) it shows up
[ WARN:0] global /usr/opencv_cuda/opencv-4.5.3/modules/videoio/src/cap_gstreamer.cpp (2057) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Internal data stream error.
[ WARN:0] global /usr/opencv_cuda/opencv-4.5.3/modules/videoio/src/cap_gstreamer.cpp (1034) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /usr/opencv_cuda/opencv-4.5.3/modules/videoio/src/cap_gstreamer.cpp (597) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created.
I wonder if I had a way to open a camera by its vid?
Thanks for your help.
I can’t help with the second half of your question, but if you monitor “dmesg --follow”, and then plug in the camera, what shows up in the logs? Also, what do you see from:
sudo lsusb -vvv -d '2ba2:4d55'
When I run “ dmesg --follow ” the logs shows messages as blow with my camera on.
[ 906.775793] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 906.800870] usb 2-1.1: device descriptor read/8, error -71
[ 906.911040] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 906.936828] usb 2-1.1: device descriptor read/8, error -71
[ 907.379131] usb 2-1.1: new SuperSpeed USB device number 4 using tegra-xusb
[ 907.400201] usb 2-1.1: New USB device found, idVendor=2ba2, idProduct=4d55
[ 907.400208] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=10
[ 907.400213] usb 2-1.1: Product: MER-131-210U3M NIR
[ 907.400217] usb 2-1.1: Manufacturer: Daheng Imavision
[ 907.400221] usb 2-1.1: SerialNumber: TA0170050027
And when I plugged my camera the logs got three line more.
[ 1183.934768] usb 2-1.1: USB disconnect, device number 4
[ 1184.134400] usb 2-1: usb_suspend_both: status 0
[ 1184.134549] usb usb2: usb_suspend_both: status 0
And that’s what i got from sudo lsusb -vvv -d ‘2ba2:4d55’.
Bus 002 Device 004: ID 2ba2:4d55
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 9
idVendor 0x2ba2
idProduct 0x4d55
bcdDevice 0.00
iManufacturer 1 Daheng Imavision
iProduct 2 MER-131-210U3M NIR
iSerial 10 TA0170050027
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 116
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 224mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 239 Miscellaneous Device
bFunctionSubClass 5 USB3 Vision
bFunctionProtocol 0
iFunction 3 USB3 Vision Device
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 239 Miscellaneous Device
bInterfaceSubClass 5 USB3 Vision
bInterfaceProtocol 0
iInterface 0
** UNRECOGNIZED: 14 24 01 00 00 01 00 00 00 01 00 04 05 06 07 08 09 0a 0b 08
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000c
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 3
Lowest fully-functional device speed is SuperSpeed (5Gbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
Device Status: 0x000c
(Bus Powered)
U1 Enabled
U2 Enabled
Thanks anyway.
Please use nvarguscamerasrc for CSI Bayer sensor. Suppose v4l2src don’t support RAW sensor capture pipeline.
